Looking to replace Zwave CA3750 w/PCS PulseWorx UPB Output Control Module & HomeSeer?
  • #16
    Good news Ray.
    Did you fit the UPB switch inside of the CA7350 box for your modification?
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.500 (Linux) - Ubuntu 18.04 64 bit Intel CPU - Mono 5.18
    Homeseer Zee2 (Lite) - 3.0.0.531 (Linux) - ARMBian Ubuntu 18.04 64 bit Arm CPU - Mono 5.20
    • #17
      Yes, fit in fine, we'll see if the SA switch holds up to the Florida summer heat & humidity
      • #18
        Yup; there the spa switches are still working. These are embedded into the surrounding cement with little rubber caps on them and the radio remote still works fine these days after some 10 years being maybe 30 feet from the water. Weather station is still working fine after after a few years.
        - Pete
        Auto mator
