I am wondering if this device, PCS PulseWorx UPB Output Control Module (OCM) by Powerline Control Systems (PCS) works OK with HomeSeer and the Spud plugin?
I am trying to control 2 low voltage loads. This device has 2 isolated relay contacts which it controls. I am looking to control a SPA using existing low voltage control wires that I had hooked up to a Zwave Intermatic ca3750 but the CA3750 died within 3 months & a new one just arrived DOA, so I am giving up on that solution & looking to control via UPB.
This device is fairly expensive ($175) so I want to be sure it will show up & both relays work ok in Upstart/HomeSeer via the plug in. My other UPB devices are Simply Automated.
