SA Input/Output module
  • SA Input/Output module
    I upgraded to HS3 and use this plugin. It works great except it will not recognize three (3)
    Simply Automated UPB Input/Output Module
    Item # SAUMI32W
    modules I have installed. How can I get the program to recognize these modules?
    please send me your .upe file so that I can replicate the problem, thanks
      upe file zipped
      Arbutus.upe.zip
        What do you mean exactly when you say the plugin doesn't recognize these modules?
        I tried importing your file, and the 3 input/ouput modules are imported just fine: 5 HS devices are created for each module (3 inputs - 2 outputs)
        If you meant that the devices are not updated or do not control the module correctly, please provide some debug logs.
        BTW impressive setup you have there!
          error log
          Thanks- it is a big house.
          Here is a portion of the log from last night.
          Jan-25 1:00:00 AM Event Event Trigger "Time Triggered Events Dog Porch Wall Light Off at 1AM"
          Jan-24 11:59:00 PM Device Control Device: All kitchen + rope to Off (0)
          Jan-24 11:59:00 PM Event Event Trigger "Time Triggered Events Kitchen off at Midnight"
          Jan-24 11:38:45 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:44 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:43 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:42 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:41 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:40 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:39 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:38 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:37 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:36 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:35 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:34 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:38:33 PM UPBSpud ERROR PIM_RCVR:: UPB_MGR:: ERROR: Error parsing received string -- Index was outside the bounds of the array.
          Jan-24 11:34:12 PM UPBSpud ERROR DEVICE[108]:: Unknown channel report for device (channel 3) -- ignored
          Jan-24 11:34:11 PM UPBSpud ERROR DEVICE[108]:: Unknown channel report for device (channel 3) -- ignored
          Jan-24 11:34:07 PM UPBSpud ERROR DEVICE[107]:: Unknown channel report for device (channel 3) -- ignored
          Jan-24 11:34:06 PM UPBSpud ERROR DEVICE[107]:: Unknown channel report for device (channel 3) -- ignored
          Jan-24 11:34:05 PM UPBSpud ERROR DEVICE[106]:: Unknown channel report for device (channel 3) -- ignored
          Jan-24 11:34:04 PM UPBSpud ERROR DEVICE[106]:: Unknown channel report for device (channel 3) -- ignored
            from the config page of the plugin, could you set the log level to Debug, then capture again the problem
            and please tell me what happens when the errors occurs? and what you think the device should be updated to (for example input 1 for Door 1 should be set to On, etc...)
            thanks
              scene controller error
              Here is an error that has started when I try to access a 4 button wall mounted controller (data sheet for controller attached.)
              The plugin will not recognize the state of the buttons on the controller nor will it control them despite the log showing the commands being sent. For example see see 11:33:39 device 45 is one of the 4 button scene controllers. Despite the log showing the command succeeding neither the physical scene controller button is updated nor is the status light bulb on the device page.
              See also 11:27:55 device 28 is another 4 button scene controller and thew same thing happens as noted above.
                scene controller follow up
                I noticed that all of these units imported as devices and not keypad buttons. Is that an issue?
