Do I need to delete keypad devices & links after update?
  • Do I need to delete keypad devices & links after update?
    I have 3 - 8 button keypads PCS keypads that the status lights in HS were not reflecting the status of the keypads.
    I saw you have a keypad fix 3.0.0.15 (I was on 3.0.0.13), I installed the update successfully, closed HS, reimported the upe file.
    I hope the answer is no but do I need to delete these devices & affected events in HS in order for the fix work?
    the fix done in 3.0.0.15 was for a user who reported a problem with a SA keypad which is not actually treated by the plugin as a keypad. This fix doesn't need you to delete your devices, but it will probably would not have any impact on your PCS keypads if they are already recognized as keypads by the plugin (i.e if the plugin creates device of type "UPB Keypad Button")
    the fix done in 3.0.0.14 add some indicator on/off buttons to the "UPB keypad button" devices. This one needs you to delete your keypad devices.
