BLINK Action missing from Links
  • BLINK Action missing from Links
    UPB links have the ability to command the target device to BLINK.
    In the HS2 plugin, BLINK was a selectable action. The UPB value for blink is 16 in the specification. The UPB specification supports the ability to also specify the blink rate in the link command. In the HS2 plugin, you specified via the .ini file a universal blink rate that was used for all links.
    In HS2, when my home alarm sounded, I sent a blink command to a link that was targeted (via UpStart) to all of the outside lights and others that I wanted blinking while the alarm was sounding. When the alarm was silenced, I would restore each of these devices to their prior state (non-trivial).
    So, would you consider adding a BLINK action/value for the link devices?
    tenholde
    tenholde
    yes I will add Blink to the Links devices. I will let you know when it's done.
      tenholde
        in version 3.0.0.21
        I have added the Blink feature for both links and devices
        You can choose the blink rate from the UPBSpud config page
        For the Blink button/status to be added to your devices, you need to delete your existing devices, and let the plugin recreate them after a restart.
          Appears to work correctly, thanks for the quick response.
          tenholde
          tenholde
            Originally posted by spud View Post
            in version 3.0.0.21
            Hey Spud,
            I am curious for curious sake. Is there no way to add the functionality to existing devices when making these changes to the plug-in? I only ask because deleting and re-adding to add features such as this will have me trying to locate/fix 100+ Events, Counter and Timers, not to mention all of the HSTouch broken links etc. I figure that if it could be done to add it to existing objects you would have programmed it that way but was curious to know.
            -Travis
              Oops, I didn't even think to check my events.
              Yeah, that's not so good.
              tenholde
              tenholde
                tenholde
                So, I had to change more than 40 Events, with a high degree of confidence that I broke something.
                tenholde
                tenholde
                  Yeah, I am curious if it has to be this way, that's why I asked. Spud is awesome though so he'll come back with an answer. Even if it can't be done, he sometimes will suggest things to HS Development that will allow him more flexibility etc so there could be hope in the future. Even some import/export routine would be fine. Some of my events are even using variables from his EasyTrigger plug-in (another awesome plug-in) so trying to even figure out what the heck I was doing with what variable replacement would be hard to figure out.
                  -Travis
                    Always thought it was a weakness in HS2/3 to rely on DevRef for Event references.
                    None of my scripts break, because I use the Device Floor/Room/Name to get the DevRef.
                    Just as I was becoming less reliant on scripts and placing more into the more flexible HS3 events, I find a reason to rethink and place more in scripts.
                    tenholde
                    tenholde
                      -Travis
                      yes it can be done, it is just more complicated to deal with on my side .
                      I will make the changes so that the new blink features can be added to your devices without the need to delete anything.
                        Hi Spud,
                        Great, that's perfect. I'm glad there is a solution so we don't have to redo everything. Appreciate all the effort so much so that I think I'll buy the iTunesDAAP Plug-in from you now even though I still haven't tested the Forked-DAAPD server at all yet!!
                        Thanks again,
                        -Travis
                          done in version 3.0.0.22, HS devices are now automatically upgraded.
                            Hi Spud,
                            I installed the upgrade and it looks like it installed and upgraded the devices fine. I haven't tested the functionality yet though. Unfortunately, all of my devices were using custom icons as well and I lost all of those. For instance, light bulb icons are now the On Button. Is there any way to prevent that as well in the future or is that something we will need to deal with?
                            -Travis
                              Release not in updater
                              Homeseer updater shows 3.0.0.18 as the most recent version. How do I get more recent releases?
