error on config
    error on config
    I get a title header and nothing but the word error when i try to load the config screen.
    any ideas?
    could you post your logs?
    thanks
      thanks
      Oct-25 6:40:00 PM UPBSpud ERROR Object reference not set to an instance of an object.
        can you edit the file Config/UPBSpud.ini, copy/paste the following lines in it:
        [GENERAL]
        log_level=Debug
        then restart the plugin, and post here all the logs you get from the moment the plugin starts until you try to access the config page?
        also what is the content of your UPBSpud.ini right now?
          it's fixed in version 3.0.0.28 available here
          thank you for reporting the problem
