All of a sudden no UPB communication
  • All of a sudden no UPB communication
    All of a sudden I see there is no UPB communication. Ran upstart, worked and controlled without issues.
    What do you think is the issue? Unplugged the PIM replugged it. The upstart works but HS UPB Spud gives these messages.
    Jun-22 06:50:26 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 9 [0714F609FF30B7] to PIM -- timed out 5 times -- discarding message
    Jun-22 06:51:12 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 8 [0814F607FF223C8A] to PIM -- timed out 5 times -- discarding message
    Jun-22 06:51:57 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 10 [0714F60AFF30B6] to PIM -- timed out 5 times -- discarding message
    Jun-22 06:52:42 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 11 [0714F60BFF30B5] to PIM -- timed out 5 times -- discarding message
    Jun-22 06:53:27 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 12 [0714F60CFF30B4] to PIM -- timed out 5 times -- discarding message
    Jun-22 06:54:12 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 13 [0714F60DFF30B3] to PIM -- timed out 5 times -- discarding message
    Jun-22 07:00:14 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 18 [0714F612FF30AE] to PIM -- timed out 5 times -- discarding message
    Jun-22 07:00:30 Device Control Device: 1st Floor Interior Downstairs Hall to Off (0) by/from: CAPI Control Handler
    Jun-22 07:00:59 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 12 [0814F60BFF2200C2] to PIM -- timed out 5 times -- discarding message
    Additional logging.
    Jun-22 07:12:42 Plug-In Shutting down Plug-In: UPBSpud
    Jun-22 07:12:42 Info Plugin UPBSpud with instance: has disconnected
    Jun-22 07:12:50 Info Plugin UPBSpud has connected. IP:127.0.0.1:55115
    Jun-22 07:12:51 Plug-In Finished initializing plug-in UPBSpud
    Jun-22 07:13:04 Plug-In Shutting down Plug-In: UPBSpud
    Jun-22 07:13:04 Info Plugin UPBSpud with instance: has disconnected
    Jun-22 07:15:00 Log Info The log database is currently 14.17MB in size.
    Jun-22 07:16:14 Info Plugin UPBSpud has connected. IP:127.0.0.1:55514
    Jun-22 07:16:14 Plug-In Finished initializing plug-in UPBSpud
    Jun-22 07:16:24 Plug-In Shutting down Plug-In: UPBSpud
    Jun-22 07:16:24 Info Plugin UPBSpud with instance: has disconnected
    Jun-22 07:16:58 Info Plugin UPBSpud has connected. IP:127.0.0.1:55655
    Jun-22 07:16:58 Plug-In Finished initializing plug-in UPBSpud
    Jun-22 07:17:40 Device Control Device: 1st Floor Interior Downstairs Hall to Off (0) by/from: CAPI Control Handler
    Jun-22 07:17:42 Device Control Device: 1st Floor Interior Downstairs Hall to Off (0) by/from: CAPI Control Handler
    Jun-22 07:17:43 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 1 [0714F601FF30BF] to PIM -- timed out 5 times -- discarding message
    Jun-22 07:17:44 Device Control Device: 1st Floor Interior Bay China Lamp to Off (0) by/from: CAPI Control Handler
    Jun-22 07:18:28 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 1 [0814F602FF2200CB] to PIM -- timed out 5 times -- discarding message
    END
    HS3 Standard Edition 3.0.0.258
    anything recently changed on your setup that could be related to this problem?
    are you sure that COM1 is the com port used by your PIM? Make sure there is no other software using the PIM, and make sure you don't have ghost HSPI_UPBSpud.exe processes still running.
    could you set the log level to debug from the config page, and then restart the plugin?
      Com 3 is the connection to use. Upstart confirmed this without issues. I upgraded to latest version of upstart this AM in hopes of a solution.
      Is there an basic test for upbspud to confirm it has a connect to PIM, does that show in debug log in a specific string?
      This has run for years and through HS3 upgrade 7 months ago.
      Please confirm serial speed 9600, parity 8 , none and 1, and so on , flow control is set to none.
      PIM is used at which type pulse or message? (upstart can end and set the value)
      It is as if HS / upbspud is not getting through to serial port. Checked win 10 device and it is there and indicates serial / usb connected when I plug in the cable. Cannot think of any other area to check?
      What is odd is that HS / upb does not communicate on com3, but upstart works fine on com3.
      Tested back and forth, upbspud no communication then switch to upstart works file. All on com3, upb complains on com3 upstart does not.
      Checking a few things. There should only be 1 HSPI_UPBSpud.exe running.
      should I do a re-install of upbspud? And will I loose anything?
      Why does upb plugin have a config for com s and manage plugins has a selection for com s also?
      In the files I sent with debug on, it shows disconnect -I started upstart and works fine- connect to upbspud - no communication? Every time I test.
      Can I reinstall HS without loosing my environment.... refresh the software?
      I will set debug again and restart only the plugin and forward you the results.
      Thanks again.
        UPBSpud config page has a setting for COM port because the management of COM port from HS (manage plugin page) is buggy. So make sure the correct value is set in the config page.
        In the first UPBSpud.ini you sent me it is set to COM1, and in the second one it is set to com3. I think it needs to be upper case so set it to COM3.
        The plugin use message mode.
          All of a sudden no UPB communication -- SOLVED
          The use of uppercase COM3 immediately had the upbspud cranking again.
          All good now!
          Thanks for your help, Spud.
          That made the difference.
          On a different question, I will send you my .upe file if I cannot get a specific device from upstart (SA lamp module) to show up in upbspud. It has been flakey.
          Take care.
          Richard.
