I believe I've found a bug:
I have several UPB plug-in modules. Most control lights; one controls an air filter.
If I use Upstart to set the plug-in module that controls the airfilter to not permit dimming, then when I attempt to set a 'device action' in an HS event for this device, the drop down list of actions includes several incorrect options ("All lights off", for example), and when I select elements from the drop down list, they are not correctly interpreted.
If I turn dimming back on (using Upstart), then I get only three device action options: On, Off, and Dim, which is correct.
Jerry
Jerry
