I have various UPB switches and plug in modules from SA. I also have a coupler from SA (the kind that looks like it replaces cuircuit breakers).
I have one circuit where neither the switches nor the plugs work. The noise level is always high and signal strength is very weak. The interesting thing is that X10 works just fine.
I've tried shutting off all the obvious things such as TV's, Fans, lights, etc. Still the noise persits. I can't add the switches because UPBStart doesn't see it. I was able to see the noise and signal by adding a plugin module using another circuit and moving it to the bad cuircuit.
Any advice? This is in a new portion of my house. Could it be a wiring problem? (Wiring checks out fine as far as the electricity, neutra, hot, ground).
