I understand that UPB signals transmit over the powerline between 4-40k. I also understand that they will leave your house and be transmitted to every other home hanging off your transformer. Conversely, your neighbor's UPB signals can and will do the same.
I also understand that UPB signals consist of a Network ID and Device ID. And that contrary to popular thought, the 4-character UPB password is only used for setup/programming mode - it is not encrypted and, more importantly, it is not used at all as a security layer for any command transmissions.
I have been told that sniffing and hijacking UPB is easy and that the potential for misuse is real. This has been confirmed by PCS/PulseWorx (inventors of UPB), Simply Automated and HAI.
While those three companies seem to recognize the need for a whole-house filter solution (either incoming, outgoing, or both) - none of them have developed one beyond a small version used for training stations.
With the help of the lead PulseWorx engineer, I was pointed in a direction to begin searching for a whole-house filtration solution to prevent the penetration of UPB signals originating from outside the house. I spent some time researching this product:
http://0036102.netsolhost.com/Docs/RP135.pdf
Unfortunately, the company will not provide specs regarding the actual 4-40k attenuation and I'm not willing to buy one to find out. I have looked high an low for a "Plug and Play" alternative - but I have come up short.
Now, I imagine this may not be important to someone controlling a lamp or two - but most people on this forum probably don't fall into that camp. I, for one, would prefer bi-directional unit (preventing outgoing and incoming UPB) - but I'd settle for incoming if I had to.
Questions:
1. Am I alone with this UPB security concern - or do any of you share this concern?
2. Does anyone else have a suggestion for 4-40k whole house filtration?
Questions:
