Anyone used HAL Appliance Module w/ SA UPB?
  • GregKing
    Martin, I was asking about local control not status. There isn't a setting to enable local control, because it looks like the HAL/SA unit doesn't support local control. Apparently, there is both a UMA and a UMA-E version from SA. The HAL device is equivalent to the UMA-E which doesn't have local control.
    products
    doc for UMA-E
  • AutomatedOutlet
    Greg,
    Look under the "Options" tab in upstart. You should see an option for reporting local status.
  • Guest's Avatar
    Guest replied
    Scott,
    FYI the UPB/HAI products sold at Fry's "were" manufactured by Simply Automated, and would be compatible.
    Dave
  • GregKing
    Local control?
    Has anybody found a solution to add local control to these modules? I use the SA UPStart and was wondering if a different version of the s/w supported configuring these modules for local control.
    gk
  • aldonc
    I've used them and they work fine.
    aldon
  • Roozter
    Great, Thank you.
  • jasv
    Yes..
    Any UPB module should work with UPStart.
  • Roozter
    Thanks. These are HAL not HAI, but I if understand correctly, you are suggesting that any UPB module should work with UPStart.
  • jasv
    UPStart shouldn't care...
    I have some HAI switches that work just fine with SM modules, Homeseer and UPBStart. I am pretty sure you won't have any issues.
  • Roozter
    started a topic Anyone used HAL Appliance Module w/ SA UPB?
    I found this appliance module at Frys.com and wondered if it will work with Simply Automated UPB?
    If the link doesn't work just search Frys.com for HAL and find the appliance module.
    http://shop3.outpost.com/%7BRw1yadtXvMmJylm1ZRnnag**.node3%7D/product/4734599;jsessionid=Rw1yadtXvMmJylm1ZRnnag**.node3?site=sr:SE ARCH:MAIN_RSLT_PG
