I have a light in a bathroom that used to function normally. all of a sudden the light only turns on by double tapping it on. I didn't change anything in upstart, that I know of. any suggestions?
only turns on with double tap
Plugins:
BLLogMonitor, BLGarbage, BLBackup, BLOutGoingCalls, BLUps, BLRfid, JvEss, DooMotion, Applied Digital Ocelot, AC RF Processor, UltraMon, PJC AVR 430, UPB, Rain8net, DSC Panel, JRiver Media center, Windows Media Player, SageMediaCenter, SnevlCID, MCSTemperature.Tags: None
Event5
What's the make and model of the switch. Have you looked at the rocker switch tab in UPStart?
It the fix isn't obvious then try factory reset and then, either do an install/replace, or build the switch from scratch.
Dave
Its a us240. for some reason, changing it from a super top rocker to a normal top rocker did the trick (figured I'd try that while i was in upstart looking at what kind of switch it is.) thanks for the help!
IanPlugins:
jay dee
i don't recall, sorry. why do you ask?Plugins:
