actvating a UPB device using Perl Script doesn't work
    I exit early in this script just to allow the one command to run with this
    sub main()
    hs.SetDeviceValue("\30", 10);exit;
    I get this...
    9/24/2008 9:09:30 PM - Error - Running script, script run or compile error in file: humidity_shower_lights_master.pl-2147467259:Can't call method "Dispatch" on an undefined value at -e line 5. in line 0 More info: Can't call method "Dispatch" on an undefined value at -e line 5.
    I get no error message when I us
    $hs->SetDeviceValue ("\30", 10);exit;
    but also no response<!-- / message -->
    <!-- controls -->
    Is there a reason you do not want to use a vb script?
    -Rupp
      I use Perl not Visual basic it was a big reason for going with HomeSeer. So UPB doesn't work for perl?
        This code snippet is so small (main plus the code line) that I'm not sure that's the issue....can you give me a VB script that activates a UPB light through a HAI panel serial interface?
        Thank you in advance
          watch the device code... it is a backslash, and Perl probably thinks you are specifying an escape sequence. you can either try using a double-backslash in the string, or change the device code for UPB objects.
            YES! Been perlizing for quite some time should have thought of that. That fixed it!!
