Well I've become a believer in this forum. I received two suggestions to resolve the problem described as upb 99 limit problem. So first let me apologize for being such a pain. Here are the two suggestions that solved the problem.
ONE)
Its possible that the UPB plugin does not like devices that use a code of "[". These codes are automatically assigned to devices when they are created. You can tell HomeSeer to not use certain codes. Try this:
1) In HS delete all of the current UPB devices that were created
2) Shut down HS and edit the file "settings.ini" which is located in the HomeSeer config folder. In the "Settings" section add this line:
IOCodesExclude=],[
Save the file, start HS and re-import your Upstart file. The above line will tell HS to not use those codes when creating devices. See if the devices can now be controlled.
TWO) Someone said if you have split phase repeaters (which I do) then you need to set the number of transmissions to at least 2.
ONE)
IOCodesExclude=],[
