Simply Automated PIM - USB
This topic is closed.
    I just received a USB model from Automated Outlet.
    Unfortunately, I didn't read the threads before I purchased it. UpStart works find but Homeseer doesn't appear to be recognizing it.
    Do I need to swap it for a serial model?
    I can't tell you for sure but from personal experiences i've found the serial model seems to give far better performance.
    Marty
    XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
    Playing with HS3 a bit but it's just play at this point.
      I tried same. I never did get the USB UPB PIM working with the plugin. I kept the USB UPB Pim for my office PC / UPB Upstart stuff. The SA serial PIM has been working fine. Actually just had a "failure" of the HAI serial UPB controller and switched over to using SA serial controller for my HAI OPII.
      - Pete
      Auto mator
        Ok. Contacted AutomatedOutlet and they are sending me the serial interface.
        Thanks.
          I had the choice of returning the PIM to HAI or AutomatedOutlet.
          Both have excellent customer service. I chose to do a cross ship of a new HAI PIM with AutomatedOutlet.
          - Pete
          Auto mator
            Glad it worked out for you!
            Martin Custer
              Received the serial interface - installed it last night and everything works.
