Yet the device is controlled just fine from HS via the UPB plug-in. This is the error log:
-----------*Pre-Error Log*----------------
6/3/2010 3:01:19 AM - PIM<--Sending 07101701FF30A2
to PIM (Try # 1)
6/3/2010 3:01:19 AM - PIM-->Received PIM Accept
6/3/2010 3:01:19 AM - Waiting for ACK/NAK from PIM
6/3/2010 3:01:20 AM - PIM-->Received PIM NoAck
6/3/2010 3:01:20 AM - PIM<--Sending 07101701FF30A2
to PIM (Try # 2)
6/3/2010 3:01:20 AM - PIM-->Received PIM Accept
6/3/2010 3:01:20 AM - Waiting for ACK/NAK from PIM
to PIM (Try # 3)
6/3/2010 3:01:21 AM - PIM-->Received PIM NoAck
6/3/2010 3:01:21 AM - PIM<--Sending 07101701FF30A2
to PIM (Try # 4)
6/3/2010 3:01:21 AM - PIM-->Received PIM Accept
6/3/2010 3:01:21 AM - Waiting for ACK/NAK from PIM
to PIM (Try # 5)
6/3/2010 3:01:22 AM - PIM-->Received PIM NoAck
6/3/2010 3:01:22 AM - ** Retry count exceeded, UPB Message transmission failed.
6/3/2010 3:01:22 AM - UPB Command transmit failure. Setting units related to UPB module ID 1 to unknown/failed state
6/3/2010 3:01:22 AM - * Setting HomeSeer device 'Living Room Light' to 'Unknown' Because of Command Transmit Failure on module ID 1
6/3/2010 3:01:22 AM - In SetIO:%1 Cmd: 17 Bright: 0 Data1: 0 Data2: 0
6/3/2010 3:01:22 AM - Ignoring SetIO (Device Housecode) for %1 Cmd: 17 Bright: 0 Data1: 0 Data2: 0 because the device table shows that it is being updated by the plug-in.
I can get and send commands from the light switch. It "works" fine.
to PIM (Try # 1)
to PIM (Try # 2)
to PIM (Try # 3)
to PIM (Try # 4)
to PIM (Try # 5)
