Contacting HomeSeer This Week
See more
See less
Missing devices from vera
  • Missing devices from vera
    hello ,
    I have installed this plugin with 1 vera 3. I noticed that 2 universal sensors with both a temperature sensor are not imported in Homeseer.
    Anyone has an idea how to troubleshoot that?
    Many thanks,
    Cor
    Looking at it closely a bit more , it looks like the child devices are not imported:
Name:	2019-11-26 07_00_47-HomeSeer Web Control.jpg
    Those are 2 universal sensors from fibaro, they should have at least 2 motion sensors each and both of them have a temperature sensor as well.
    Cor
      I deleted the plugin . started again , and now ..... over 1000 scenes created .....
      My vera 3 has only 3 devices and 3 scenes .
      I ended up putting a backup of the vera 3 , now I am back at yesterday status.
      Trying again with the vera plugin , but ...... nothing.....
Name:	2019-11-26 14_51_10-Log.jpg
        I bought Homeseer and this plugin , since it was said that homeseer was working well with vera.......
        No one has an idea how to troubleshoot this?
        Today I suddenly saw devices showing up in the correct room/floor . I was even able to run a scene on the vera from Homeseer.
        BUT the most important things don't show up:
        No temperature on the temperature sensor and the motion detectors also don't register a change:
Name:	2019-11-27 14_05_58-HomeSeer Web Control.jpg
        Thanks for your help ,
        Cor
          I will try and look into this over the next couple of days.
          Frank
            *edit* ..... I was writing thaty vera support couldn;t do anything about the +1 state , but since last night I have a -1 state , so they were able to change something
              The Vera plugin is now partially working for me .
              I do get the temperature from the sensors and als the switches status is shown on the Homeseer GUI.
              Only the motion sensors are not working.
              These screenshot is taken at the same time:
Name:	2019-11-30 11_41_42-192.168.68.10_cmh_#devices.jpg
Name:	2019-11-30 11_38_27-HomeSeer Web Control.jpg
              I see in the homeseer GUI there are some scenes created:
Name:	2019-11-30 11_53_33-HomeSeer Web Control.jpg
              Reading a lot on this forum on the vera plugin I understand these vera scenes are created for fast response for the security sensors.
              When I had troubles the previous days with the vera3 and plugin I did hit the "delete scenes" button on the vera-config in Homeseer several times. I also deleted the 4 or 5 scenes created on the vera 3 manually (this might have been a mistake and the cause of this last issue).
              So when I noticed the -1 state and saw the temperatures being updated , but not the motion sensors today I tried to disable to vera plugin , deleted the vera plugin, deleted all vera devices in homeseer, deleted all that had vera in the homeseer directory like vera.ini etc.
              Reinstalled vera plugin, and yes everything is there again , but the security sensors are not updated. Also there are no scenes created on the vera 3 this time.
              What to do?
              Many thanks for your assistance,
              Cor
                Anyone has an idea how to get the security sensors working within Homeseer?
                I also noticed this in the logs tonight:
                Dec-03 7:46:57 PM Warning Issue checking child device (2069) Vera Vera Gate Electronics T
                Dec-03 7:46:57 PM Warning Device (2068) Vera Vera Gate Bell does not reference a parent, it should reference one parent
                Dec-03 7:46:57 PM Warning Issue checking child device (2068) Vera Vera Gate Bell
                Dec-03 7:46:57 PM Warning Device (2076) Vera Vera Unversal input unuse is marked as child, but does not reference any parent
                Dec-03 7:46:57 PM Warning Issue checking parent device (2063) Vera Vera Xp_uni_sensor_gate
                Dec-03 7:46:57 PM Warning Device (2069) Vera Vera Gate Electronics T is marked as child, but does not reference any parent
                Dec-03 7:46:57 PM Warning Device (2068) Vera Vera Gate Bell is marked as child, but does not reference any parent
                Dec-03 7:46:57 PM Warning Device (2075) Vera Vera Gate Temperature is marked as child, but does not reference any parent
                Dec-03 7:46:57 PM Warning Issue checking parent device (2062) Vera Vera XP_gate sensor
                Dec-03 7:46:57 PM Warning Device (2074) Vera Vera Gate sensor right is marked as child, but does not reference any parent
                Dec-03 7:46:57 PM Warning Device (2073) Vera Vera Gate sensor left is marked as child, but does not reference any parent
                Dec-03 7:46:57 PM Warning Device (2078) Vera Vera Xe2 gate fibaro rela is marked as child, but does not reference any parent
                Dec-03 7:46:57 PM Warning Issue checking parent device (2061) Vera Vera Xp_gate relais
                Dec-03 7:46:57 PM Warning Device (2071) Vera Vera Gate no_touch_actvtr is marked as child, but does not reference any parent
                Dec-03 7:46:57 PM Warning Device (2072) Vera Vera Gate open_close VS is marked as child, but does not reference any parent
                Dec-03 7:46:57 PM Warning Issue checking parent device (2049) Vera Vera Vera Scene: HS3-2020-Off
                Dec-03 7:46:57 PM Warning Device (2077) Vera Vera Xe2 gate fibaro rela is marked as child, but does not reference any parent
                Dec-03 7:46:57 PM Warning Issue checking parent device (2047) Vera Vera Vera Scene: Sound alarm at gate
                Dec-03 7:46:57 PM Warning Device (2070) Vera Vera Gate no_touch_actvtr is marked as child, but does not reference any parent
                What does that mean?
                Cor
                  Sorry I haven't had a chance to look yet, it is on my to do and as of last night we have stopped working nights at work (lets hope that is a continuing trend).
                  Frank
                    I am not getting this plugin.
                    -Today I suddenly got about 20 scenes on my vera 3. So I clicked the "delete scenes"on the vera plugin.
                    -switches and temperatures are nicely updated , but motion sensors not.
                    -an everpring motion sensor even has no "normal" motion sensor icon (motion detect 6):
Name:	2019-12-10 18_34_09-HomeSeer Web Control.jpg
                    What can I do ? how to troubeshoot?
                    Cor
                      Let me look into it. LIfe is returning to normal now and I am starting to get back into plugins.
                      Frank
