I can confirm that this plug-in works with Vera Lite running UI5. I use the Vera Lite to control an Ethernet Relay Board Model ETH008. I do this because the micasaverde plug-in to control the board only works in UI5. I had been running the Vera Lite as a stand-alone controller for water valves attached to the relay board, but this meant I could only use sensors that worked with UI5. Now I can use more current sensors included into the HS system and then control the relays using the HS Vera plug-in. I have no Z-wave devices included in the Vera Lite, just the relay board. Eventually I plan to work out the scripts to control the board directly, but for now this is a good workaround.
