Contacting HomeSeer This Week
See more
See less
Wemo keeps crashing :(
  • Wemo keeps crashing :(
    Failed to start in HS3 (Pro Edition 3.0.0.548 on Linux)
    Nov-20 10:23:05 PM Info Plugin Wemo has connected. IP:127.0.0.1:36220
    Nov-20 10:23:04 PM Warning I/O interface Wemo is down, executable is not running, restarting ...
    Nov-20 10:22:39 PM Info Plugin Wemo with instance: has disconnected
    Nov-20 10:22:34 PM Starting Plug-In Plugin Wemo started successfully in 351 milliseconds
    Nov-20 10:22:34 PM Starting Plug-In Initializing plugin Wemo ...
    Nov-20 10:22:33 PM Starting Plug-In Wemo loaded in 15061 milliseconds
    Nov-20 10:22:20 PM Info Plugin Wemo has connected. IP:127.0.0.1:36218
    Nov-20 10:22:18 PM Warning I/O interface Wemo is down, executable is not running, restarting ...
    Nov-20 10:21:54 PM Info Plugin Wemo with instance: has disconnected
    Nov-20 10:21:49 PM Starting Plug-In Plugin Wemo started successfully in 355 milliseconds
    Nov-20 10:21:48 PM Starting Plug-In Initializing plugin Wemo ...
    Nov-20 10:21:48 PM Starting Plug-In Wemo loaded in 15065 milliseconds
    Nov-20 10:21:34 PM Info Plugin Wemo has connected. IP:127.0.0.1:36216
    Nov-20 10:21:33 PM Warning I/O interface Wemo is down, executable is not running, restarting ...
    Nov-20 10:21:08 PM Info Plugin Wemo with instance: has disconnected
    Nov-20 10:21:03 PM Starting Plug-In Plugin Wemo started successfully in 356 milliseconds
    Nov-20 10:21:03 PM Starting Plug-In Initializing plugin Wemo ...
    Nov-20 10:21:03 PM Starting Plug-In Wemo loaded in 15066 milliseconds
    Nov-20 10:20:49 PM Info Plugin Wemo has connected. IP:127.0.0.1:36214
    • When did this start happening?
    • What version of the plugin are you running?
    • What OS are you using Linux? Windows?
    • Have you recently changed anything on the system?
      * When did this start happening?
      It didn't work after installation.
      * What version of the plugin are you running?
      1.2019.712.1745
      * What OS are you using Linux? Windows?
      Current version is: HS3 Pro (SEL) Edition 3.0.0.548
      * Have you recently changed anything on the system?
      No, just installed this plugin
        I’m wondering if there is any way to make it work?
          I'm guessing maybe the mono version is too old for the plugin. What mono version is installed?
          mono -V
          https://helpdesk.homeseer.com/articl...-sel-to-mono-5
            $ mono -V
            Mono JIT compiler version 5.16.0.179 (tarball Thu Oct  4 10:29:45 UTC 2018)
                TLS:           __thread
                SIGSEGV:       altstack
                Notifications: epoll
                Architecture:  x86
                Disabled:      none
                Misc:          softdebug
                Interpreter:   yes
                LLVM:          yes(3.6.0svn-mono-/)
                GC:            sgen (concurrent by default)
              Is this too old?
                I just found this error from the log after reinstalling the plugin:
                Warning, Cannot load EXE file (possibly missing dependencies) HSPI_Chromecast.exe: Exception of type 'System.Reflection.ReflectionTypeLoadException' was thrown.Warning, Error details with EXE HSPI_Chromecast.exe: Could not load file or assembly 'System.Runtime, Version=4.0.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies.
                Hope it helps to diagnose the problem
                  HSPI_ChromeCast? That's not even this plugin.
                    Lool
                      Oops, forgot to share the full context: given that the mono framework may be the problem, I tried to install another plugin using mono too. I picked chromecast and installed it together with Wemo. Then, I found this detailed error log.
                      The chromecast plugin error was actually very helpful, and led me to a discussion of installing mono-complete, which actually resolved the problem of wemo too.
                      my 2c of this issue: probably, you may consider to produce some error log, instead of failing silently. It will better help other users and you to diagnose the problem
