Noob question.... I see that an XTB-523 uses a rj11 jack to interface with a PC with HS3. What type of hardware do I need on the PC side? Do I use a serial port? If so, what is the pin out of the cable on both ends? Are there any other PC interfaces that can be used.....like USB?
XTB-523 X10 interface cable
Welcome to the forum Bugman1400!
The XTB-523 is a TW-523 device.
I am currently using Jeff Volp's two phased TW523 device with my Leviton OmniPro 2
It is just an RJ11 connection as I have redone my wiring going from cat5X baluns to old telephone wire.
See here for information relating to the XTB-523 and here.
You can plug the device in to an Ocelot and use GTS CPUXA Ocelot Plug-in (3P) for X10 control.
I have tested the GTS CPUXA Ocelot Plug-in to work fine with the TW-523 X10 device.Last edited by Pete; November 24, 2017, 09:28 AM.- Pete
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X - HSTouch on Intel tabletop tablets
HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104
HS4 Lite -X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Smartthings hub, Hubitat Hub, and Home Assistant
The Ocelot is a combo AD and X10 and more device which has been around now for a very long time (~20 years).
Alternative is to utilize a CM11A or a Volp XTB-232.
I have two of Jeff Volp's X10 devices here that have worked fine for years.
I am currently using the CM11A with said above plugin and it works great.
I see a couple of CM11A's on Ebay for less than $20.
Mark Fisher (X10 author) Obi Wan has perfected the current X10 for Homeseer plugins. Today you can see much diagnostics on the plugins.- Pete
Serial Card vs. USB to serial
I'm also using the CM11A but I learned the hard way that you need to install a quality serial card in your computer. I had 2 different USB to Serial (RS232) adapters and never got things working 100%. After I installed the card, I have a very reliable X10 system.
Cheers,
Wade
