Did you enable voice command on those X-10 devices then scan devices in Alexa?
More x10 Crazyness
Has been working rater well (dropped command here and there) about a month ago started getting spurious devices turning on, different ones on different house codes.
Here now leave the old Elk X10 meter on line on the computer rack.
Last summer had a similiar issue crop up and it was related to the AC compressor motor going out. Replaced AC and all is well.
Today primarily utilize UPB switches for my lightning here. I would say that UPB is powerline on steroids. Works well for me. I have gone to utilizing multiple switch toggler on single switches to reduce the footprint a bit. These 2-4-6 toggle switches are mostly used a primary switch and scene switches and single and double tap use. They are all the same with a single tap bring the lamps to a preconfigured dim and double taps doing 100% instant light. That and here in the midwest have conduit / metal boxes and have built new using metal conduit and boxes (paying a premium over default electrical).
X10 wired and wireless is around and mostly used at the end of the year for the Christmas lighting. Here pack up the outdoor old Black and Decker Freewire stuff in the Christmas tupperware containers.
By default voice control is enabled on all of your HS3 devices. Not sure if there is a settings switch to disable all of the voice control in all of the variables.- Pete
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X - HSTouch on Intel tabletop tablets
HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104
HS4 Lite -X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Smartthings hub, Hubitat Hub, and Home Assistant
Originally posted by semibogus View PostYou mentioned in your post that you have Alexa working with the x10 in Homeseer?
I cannot seem to get it working. I have the app and the Homeseer connected but Alexa never "sees" My x10 stuff. I have no problems with any of the other connections just the x10. Wondering if I am missing something obvious? My HS3 is the Pi version. But that should not make a difference.
Ian
As the previous poster stated make sure you have Voice Command ticked for each x10 device. I'm running Alexa on a Pi as well.
