Thanks for the info!
Yes, calls to hs.ExecX10 no longer work in HS3. However, the functionality still exists within the X10 plugin (not the CM15a plugin) and you can call the ExecX10() function from a script. The details are in this thread: https://forums.homeseer.com/showthread.php?p=1217862
Let me know if you have any questions!
X10 Device Polling
X10 Device Polling
Sorry about that... I should have included in the first message.
Using a X10 CM11a
HomeSeer Version: HS3 Standard Edition 3.0.0.368
Operating System: Microsoft Windows 10 Home - Work Station
System Uptime: 2 Days 21 Hours 8 Minutes 55 Seconds
Number of Devices: 87
Number of Events: 166
Available Threads: 400
Enabled Plug-Ins
1.3.3.0: SimpleRF
3.0.0.36: X10
3.0.1.130: Z-Wave
I will have to look at this and get back to you.
A few questions so I know which code base to look at:
1) What OS are you running the plugin under: Windows or Linux?
2) Which interface are you using?
3) Which plugin (X10 or CM15a) and version are you using?
