X10 commands over Ethernet to Arduino? [Not supported]
Originally posted by Bugman1400 View PostI guess I’m stuck between the Arduino plugin and the X10 plugin. I have an Arduino Uno w/ an Ethernet shield, terminal board, and TW523 device. I was able to use the Arduino X10 libraries and hard coded a sketch (Blink sketch) to send On/Off commands to my X10 devices. Now, I would like to use a similar Blink program to send the On/Off commands over Ethernet via HS3.
X10 commands have to be translated by a PIM before being transmitted on the power line. Is it your intention to send the commands by Ethernet to your TW523 using the Uno X10 library as the translator?
Why?Mike____________________________________________________________ __________________
I would like to send the X10 commands over Ethernet to my Arduino. The Arduino is already connected to my XTB-IIR. The current Blink sketch in the Arduino will be replaced so, I can send other commands instead of just the On/Off.Last edited by Bugman1400; February 18, 2018, 06:20 PM.
Sorry, but neither the X10 plugin nor CM15a plugin support sending/receiving X10 data over ethernet to/from an Arduino.Best regards,
-Mark-
If you're not out on the edge, you're taking up too much room!
Interested in 3D maps? Check out my company site: Solid Terrain Modeling
