HomeSeer sporadically loses connection with CM15A
Well, it has gotten worse. I need to restart the homeseer box or restart the plugin every couple of hours now. Any ideas?
I am having the same issue. Cm15a becomes disconnected every few days. Restarting the plugin fixes it for a while. At this point the system is less stable than my old Active Home which is pretty sad. Any idea how to fix this? I have the latest released version of the plugin.
Thanks for your help.
TJ
Log upon failureMay-04 6:55:59 AM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused May-04 6:55:54 AM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused May-04 6:55:49 AM CM15A Unable to send to CM15A: The operation is not allowed on non-connected sockets. May-04 6:55:49 AM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused May-04 6:55:49 AM CM15A Unable to send to CM15A: Unable to write data to the transport connection: The socket has been shut down. May-04 6:55:49 AM Event Event Trigger "Light Groups Den Lights Off" May-04 6:55:49 AM Event Event Trigger "Motion Detector Den Motion Off" May-04 6:55:49 AM Z-Wave Device: Downstairs Den Motion Set to NOTIFICATION for type Home Security, Event: No Event May-04 6:38:56 AM Event Event Trigger "Light Groups Upstairs Lights Off"
Log after restartMay-04 7:00:40 AM Event Event Trigger "Outside Lights Front Yard Lights Off" May-04 7:00:40 AM Event Event Outside Lights Front Yard Lights Off triggered by the event page 'Run' button. May-04 7:00:24 AM Plug-In Finished initializing plug-in CM15A May-04 7:00:24 AM Starting Plug-In CM15A loaded in 2503 milliseconds May-04 7:00:24 AM Starting Plug-In Plugin CM15A started successfully in 1443 milliseconds May-04 7:00:23 AM CM15A Initialization Successful. May-04 7:00:22 AM CM15A mochad is not running, starting... May-04 7:00:22 AM Starting Plug-In Initializing plugin CM15A ... May-04 7:00:22 AM Info Plugin CM15A has connected. IP:127.0.0.1:42848 May-04 7:00:14 AM Info Plugin CM15A with instance: has disconnected May-04 7:00:14 AM Plug-In Shutting down Plug-In: CM15A May-04 7:00:10 AM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused May-04 7:00:04 AM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused May-04 6:59:59 AM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused May-04 6:59:54 AM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused May-04 6:59:49 AM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...:
homeseer dataCurrent Date/Time: 5/4/2019 7:32:26 AM CDT HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.531 (Linux) HomeSeer: Is Registered System Uptime: 0 Days 0 Hours 59 Minutes 27 Seconds User Name and Access Level: tjankovs (Admin) LAN IP Address: 192.168.1.221 (HomeTrollerZeeS2V5) Client IP Address: 192.168.1.209 (192.168.1.209) External IP Address: 104.188.236.17 (104.188.236.17) Network Adapter: HomeSeer Adapter -> Loopback Address (localhost) IP: 127.0.0.1 Web Server Port: 80 Number of Devices: 69 Number of Events: 73 Event Last Ran: Outside Lights : Backyard Lights Off, Ran at 5/4/2019 7:00:50 AM Number of unique event scripts used: 0 Plug-Ins Enabled: Z-Wave:,CM15A: Modules/Threads: 65 Modules, 41 Threads Available Threads: 399 HomeSeer Memory Used: 88 Mbytes Plug-In Memory Used:
You'll need to do a little more research on this. Here's a good starting point to set up the service properly https://sourceforge.net/p/mochad/act...24ca5eb45a6a88
Just make sure you are using Mochad 17
Maybe not. Can you explain how to setup this daemon to work stable?
Hello,
Have you solved this issue? I've the same...
Every few days I have to disable/enable plugin or restart whole HomeTroller Zee S2
Rafal
Looks like it starting fine .....
Starting Plug-In ... Plugin CM15A started successfully in 501 milliseconds
then the mochad service is not found ...
then it restarts the mochad service....
then it connects...
Plugin CM15A has connected. IP:127.0.0.1:52868
Just to confirm that it is running fine; I would enable debug first....once connected there is a lot of chatter that you will see..
If you confirm the chatter to the CM15A then following the documenation to create an X10 device. It has to be created manually versus the device being automagically created.
Put Homeseer 3 / Installed Plugins in Develope mode (check box) first then make sure the debug flag is enabled in the ini file.
Here continue to utilize a CM11A for powerline and a W800 for wireless X10.
My cm15a works from laptop using Active Home, but no longer works with my Zee2 Hometroller. Tried different cables, usb slots etc.
This is what my log shows.
Dec-01 6:11:29 PM Info Processing updates completed. Dec-01 6:11:29 PM Info System connected to MyHS Service successfully with license ID 98517. Dec-01 6:11:29 PM Info Latest BETA update available is: 3.0.0.483 Dec-01 6:11:29 PM Info Latest update available is: 3.0.0.475 Dec-01 6:11:29 PM Info System connected to MyHS Service, waiting for acknowledge... Dec-01 6:11:28 PM TTS Speak ():Welcome to Home-Seer Dec-01 6:11:28 PM Startup Scripting is OK and is now running Startup.vb Dec-01 6:11:28 PM Info Checking for updates... Dec-01 6:11:28 PM Startup HSSentry is disabled in Setup, sentry will not be started. Dec-01 6:11:28 PM Startup Starting Event Scheduler... Dec-01 6:11:24 PM Startup Running the startup script Startup.vb Dec-01 6:11:24 PM System Synchronizing events from 12/1/2018 6:11:24 AM until now Dec-01 6:10:36 PM Starting Plug-In Plugin CM15A started successfully in 501 milliseconds Dec-01 6:10:35 PM CM15A Initialization Successful. Dec-01 6:10:35 PM CM15A mochad is not running, starting... Dec-01 6:10:35 PM Starting Plug-In Initializing plugin CM15A ... Dec-01 6:10:35 PM Info Plugin CM15A has connected. IP:127.0.0.1:52868 Dec-01 6:10:34 PM Startup Powerfail Recovery will take place in 30 Seconds Dec-01 6:10:34 PM Startup Starting Find service... Dec-01 6:10:34 PM Startup Updater services starting... Dec-01 6:10:34 PM Database Opening (Mode=Read/Write) up HomeSeer Energy database /usr/local/HomeSeer/Data/Energy/Energy.hsd Dec-01 6:10:34 PM Speech Listening for remote speaker connections on port 10401 Dec-01 6:10:34 PM Startup Initializing Speaker Client Interface Dec-01 6:10:34 PM Startup Start automation engine... Dec-01 6:10:34 PM Web Server Web Server started on port 80 Dec-01 6:10:34 PM Web Server Local IP address is: 192.168.86.21 Dec-01 6:10:34 PM Startup HStouch server started, waiting for clients to connect. Dec-01 6:10:34 PM HSTouch Server Server started on port 10200 Dec-01 6:10:34 PM Plug-In Finished initializing plug-in CM15A Dec-01 6:10:34 PM Startup Initializing Plug-Ins Dec-01 6:10:34 PM Plug-In Found plug-in: CM15A, version: 3.0.0.5 Dec-01 6:10:33 PM Database Opening (Mode=Read/Write) up HomeSeer LOG database /tmp/HomeSeerLog.hsd Dec-01 6:10:33 PM Startup Checking for available plug-ins Dec-01 6:10:33 PM Info Remote plug-in API interface started on port 10400 Dec-01 6:10:33 PM Startup This version of HomeSeer is registered as a HS3ZEES2 version. Dec-01 6:10:33 PM Startup Creating Speaker Client Interface Object... Dec-01 6:10:33 PM Startup HomeSeer version is: 3.0.0.475 Dec-01 6:10:33 PM Load Config Loading TIMERS... Dec-01 6:10:33 PM Load Config Loading COUNTERS... Dec-01 6:10:33 PM Load Config 12 total events loaded. Dec-01 6:10:32 PM Load Config Loading Events... Dec-01 6:10:32 PM Load Config Loading Event Groups... Dec-01 6:10:32 PM Load Config 11 total devices loaded. Dec-01 6:10:32 PM Database Loading Devices... Dec-01 6:10:32 PM Database Opening (Mode=Read Only) up HomeSeer database /usr/local/HomeSeer/Data/HomeSeerData.hsd Dec-01 6:10:32 PM Startup Loading configuration file ... Dec-01 6:10:32 PM Startup Database SAVE process started. Dec-01 6:10:32 PM Startup Local voice recognition class started. Dec-01 6:10:32 PM Startup Plug-In Interface class started. Dec-01 6:10:32 PM Startup E-Mail RECEIVE class started. Dec-01 6:10:32 PM Startup E-Mail SEND class started. Dec-01 6:10:32 PM Startup Web server class started. Dec-01 6:10:32 PM Startup Application interface class started. Dec-01 6:10:32 PM Startup COM port classes started. Dec-01 6:10:32 PM Startup Creating Class Objects... Dec-01 6:10:32 PM Startup Dec-01 6:10:32 PM Startup ************************************************************ ******************** Dec-01 6:10:32 PM Startup HomeSeer version 3.0.0.475 Edition: HS3 ZEE S2 Starting Now Dec-01 6:10:32 PM Startup ************************************************************ ******************** Dec-01 6:10:32 PM Startup Dec-01 6:10:32 PM Startup Settings Loaded.
Hello Brian, my apologies for the delay in getting back to you.
Version 3.0.0.5 of the HS3 CM15a Linux plugin in the updater is the latest, so you are running the most current version. Only beta releases are posted on the message board and those must be installed manually by copying file(s) into the HS3 directory.
Code:Jun-03 8:56:33 PM Z-Wave Device: First Floor Kitchen Outside Back Lights Set to OFF Jun-03 8:56:33 PM Event Event Trigger "Lighting Outback off to X10" Jun-03 9:01:16 PM CM15A Unable to send to CM15A: Unable to write data to the transport connection: The socket has been shut down. Jun-03 9:01:16 PM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused Jun-03 9:01:18 PM CM15A Unable to send to CM15A: The operation is not allowed on non-connected sockets. Jun-03 9:01:21 PM CM15A Unable to send to CM15A: The operation is not allowed on non-connected sockets. Jun-03 9:01:21 PM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused Jun-03 9:01:27 PM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused Jun-03 9:01:32 PM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused Jun-03 9:01:37 PM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused Jun-03 9:01:42 PM CM15A Connected to CM15A successfully.
HomeSeer3 <--> CM15a Plugin <--TCP/IP--> MOCHAD <--> UDEV (Linux) <--> USB Port <--> USB Cable <--> CM15a
MOCHAD is a linux driver for the CM15a. It is started by linux (not HomeSeer or the plugin) when a CM15a is attached to the system and it is stopped when the CM15a is disconnected. The CM15a plugin opens a 'connection' to MOCHAD to communicate and errors out when it cannot talk to MOCHAD, just like you are seeing.
A few questions to get the troubleshooting started:
1) Are you certain that the CM15a is powered on all the time?
2) Is the physical connection (USB) between the CM15a and the HS box firm and solid? (No chance the cable is loose).
3) Have you tried a different USB cable?
4) Have you installed any software on the HomeTroller other than HS3 plugins?
5) Do you have any experience with linux and using SSH?
As a quick test, the next time it fails please try the following before disconnecting the CM15a:
1) Go to the Manage Plugins page in HS3 and disable the CM15a plugin
2) Once the plugin is shutdown re-enable the CM15a plugin
3) Note the plugin status after the plugin has enabled
4) Copy and post the relevant entries from your log and plugin status here
Also, please reboot your HomeTroller and post a copy of the log from startup until a bit after the CM15a plugin is initialized and an attampt is made to control an X10 device. Please attach it as a text file to your post if it's really long.
I don't know what sets this off. I was able to fix it by unplugging and reconnecting the USB cord, as the log suggested. It happens every few days.
Any ideas? Thanks!
Log:
Jun-03 9:01:42 PM
CM15A Connected to CM15A successfully. Jun-03 9:01:37 PM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused Jun-03 9:01:32 PM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused Jun-03 9:01:27 PM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused Jun-03 9:01:21 PM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused Jun-03 9:01:21 PM CM15A Unable to send to CM15A: The operation is not allowed on non-connected sockets. Jun-03 9:01:18 PM CM15A Unable to send to CM15A: The operation is not allowed on non-connected sockets. Jun-03 9:01:16 PM CM15A Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused Jun-03 9:01:16 PM CM15A Unable to send to CM15A: Unable to write data to the transport connection: The socket has been shut down. Jun-03 8:56:33 PM Event Event Trigger "Lighting Outback off to X10" Jun-03 8:56:33 PM Z-Wave Device: First Floor Kitchen Outside Back Lights Set to OFF
System Profile:
Current Date/Time: 6/3/2018 9:04:54 PM
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.423
Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 7 Days 8 Hours 47 Minutes 39 Seconds
IP Address: 192.168.1.112
Number of Devices: 16
Number of Events: 9
Available Threads: 394
HSTouch Enabled: False
Event Threads: 0
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed:
Enabled Plug-Ins
3.0.0.5: CM15A
3.0.1.130: Z-WaveTags: None
