Wrong Unit Code Detected
  • Wrong Unit Code Detected
    The system is apparently interpreting Unit Code 11 as Unit Code 1.
    I remember a while back reading that it was suggested that House Codes A,M, and P were codes to be avoided. Couldn't find the exact article but here's a link to where this is mentioned.
    http://jvde.us/forum/index.php?topic=59.0
      This is a bug in the Linux version of the CM15a plugin, not the hardware. When evaluating triggers 2 digit addresses are incorrectly truncated to a single digit.
      I will look at this issue along with the 'All Units' issue you reported previously when I am able.
      Best regards,
      -Mark-
        Is there already a fix for this problem?
        10 and higher are not working, they are all seen as "1"
        Please make a fix
          Is there a FIX comming for this BUG
            Yes, sorry. Currently working on getting the HS3 X10 plugin running under HS4 and will then incorporate my findings, and this fix, into the Linux CM15a code.
            Best regards,
            -Mark-
