So I'm finally switching over from HS2 to HS3 soon, and have retired most of my X10 devices to improve WAF, but I will still have a handful of X10 wired devices. I currently have a Smarthome 1132CU interface that works pretty well (it does need to be reset on rare occasion, but not often enough to replace, and it might even be the host computer's fault as much as the device)...
My question is, I've seen a couple references to "just use the HomeSeer X10 plugin", but there are two options listed in the updater, neither called simply "X10 plugin".
Should I be installing the CM11 plugin or the CM15 plugin with the Smarthome PowerLinc Controller?
Chris
Chris
