CM15A plug-in on my fresh flashed micro SD card not working
    I have a ZeeS2 running well since 2014. I wanted to update the MONO but had no recollection of the PW, and I was unable to do a factory reset, due, I think because there were errors showing on bootup, possibly due to the number of hard resets I have had.
    I downloaded and flashed a new HTZeeS2V51419.zip(.img), Set up the Zee registration and preserved the new password. I used my saved Config file to restore HS3 and found that I had to recreate all the events. A pain, but tolerable due to simplicity of my setup. I updated to MONO 5, no problems
    I have the the native included ZWAVE 3.0.1.252 plugin installed: no problems
    I added UltraNetatmo3 plugin 3.0.6908.18500 plugin installed for my indoor/outdoor/rain gage. Also, no problem.
    HERE’s my problem:
    I tried to add the CM15A plugin(I had it on my original system) for my X10 devices.
    On the “Installed Plug-Ins” page, the status is a nice green “OK”, BUT I get the following when looking at the Pi Screen:
    mochad [4230]: Could not find/open CM15A/CM19A -5
    CM15A reconnect failed: Connection refused
    From my LOG window
    Mar-08 5:01:45 PM
    CM15A
    Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused
    Mar-08 5:01:35 PM
    Plug-In
    Finished initializing plug-in CM15A
    Mar-08 5:01:35 PM
    Starting Plug-In
    CM15A loaded in 3304 milliseconds
    Mar-08 5:01:35 PM
    CM15A
    Mar-08 5:01:34 PM
    CM15A
    Initialization Successful.
    Mar-08 5:01:34 PM
    CM15A
    Error connecting to CM15A service: Connection refused
    Mar-08 5:01:34 PM
    CM15A
    mochad is not running, starting...
    Mar-08 5:01:34 PM
    Starting Plug-In
    Initializing plugin CM15A ...
    Mar-08 5:01:33 PM
    Info
    Plugin CM15A has connected. IP:127.0.0.1:58230
    This goes on forever..
    What am I doing wrong, or what am I missing? I don’t remember having any issues the first time I installed this plugin 4 years ago.
    (I do have mochad 0.1.16 directory, so presumably mochas is installed)
    I have read every post about CM15A and mochas, but I haven’t seen a solution to my issue.
    any help, before I make another help ticket would be greatly appreciated.
    thanks, paul
