I am really puzzled by my X10 Leviton 4 button keypad... I created 4 devices in HS, keypad 1 = code I1, keypad 2=code I2 etc. When sending commend from HS to the keypad everything behaves as expected. When operate the keypad manually, log in HS seems normal (did I miss something in the log below?) but no matter which number keypad you press, it always changes keypad 1 devise in HS. For example, if you press keypad 2, keypad 2 device in HS doesn't change, but keypad 1 device in HS does.
Here are some logs:
----- HS turns on keypad 1, keypad 1 responds normally -------
Nov-25 9:19:26 PM Device Control Device: First Floor Family Room Family Rm Keypad 1 to On (100) by/from: CAPI Control Handler
Nov-25 9:19:26 PM X10 INFO SendX10: I1 Cmd: 2 Dim: 0 Data1/2: 0/0
Nov-25 9:19:26 PM X10 INFO Output Dequeue: $>28001I01I01 D1#
Nov-25 9:19:26 PM X10 INFO Output Dequeue: adr
Nov-25 9:19:26 PM X10 INFO Output Dequeue: $>28001IONION 49#
Nov-25 9:19:26 PM X10 INFO Output Dequeue: cmd2
Nov-25 9:19:27 PM X10 INFO Raw Poll: 76767.131166 - $<2800! I01I01 IONIONAB#
Nov-25 9:19:27 PM X10 INFO InParsed(0): $<2800! I01I01 IONIONAB#
Nov-25 9:19:31 PM X10 INFO ProcessX10: $<2800! I01I01 IONIONAB#
----- HS turns on keypad 2, keypad 2 responds normally -------
Nov-25 9:29:21 PM Device Control Device: First Floor Family Room Family Rm Keypad 2 to On (100) by/from: CAPI Control Handler
Nov-25 9:29:21 PM X10 INFO SendX10: I2 Cmd: 2 Dim: 0 Data1/2: 0/0
Nov-25 9:29:21 PM X10 INFO Output Dequeue: $>28001I02I02 D3#
Nov-25 9:29:21 PM X10 INFO Output Dequeue: adr
Nov-25 9:29:21 PM X10 INFO Output Dequeue: $>28001IONION 49#
Nov-25 9:29:21 PM X10 INFO Output Dequeue: cmd2
Nov-25 9:29:24 PM X10 INFO Raw Poll: 77364.8950916 - $<2800! I02I02 IONIONAD#
Nov-25 9:29:24 PM X10 INFO InParsed(0): $<2800! I02I02 IONIONAD#
Nov-25 9:29:28 PM X10 INFO ProcessX10: $<2800! I02I02 IONIONAD#
----- Manually turns on keypad 1, keypad 1 device in HS turns on -----
Nov-25 9:31:29 PM X10 INFO Raw Poll: 77489.3028992 - $<2800! I01I01 IONIONAB#
Nov-25 9:31:29 PM X10 INFO InParsed(0): $<2800! I01I01 IONIONAB#
Nov-25 9:31:33 PM X10 INFO ProcessX10: $<2800! I01I01 IONIONAB#
Nov-25 9:31:33 PM X10 INFO Callback: Dev= I1, HC= I, Cmd= 2, 0/0
---- Manually turns on keypad 2, keypad 1 device in HS turns on despite log shows I2 address ----
Nov-25 9:36:02 PM X10 INFO Raw Poll: 77762.136313 - $<2800! I02I02 IONIONAD#
Nov-25 9:36:02 PM X10 INFO InParsed(0): $<2800! I02I02 IONIONAD#
Nov-25 9:36:06 PM X10 INFO ProcessX10: $<2800! I02I02 IONIONAD#
Nov-25 9:36:06 PM X10 INFO Callback: Dev= I2, HC= I, Cmd= 2, 0/0
Here are some logs:
