Hello all, i'm moving from HS2 WIN XP to HS3 on Raspberry PI3, version 3.0.0.548.
My problem is the following : i have connected a CM15PRO, the device is well recognize at startup (can be seen with dmesg), and also well started by HS3 (connection established seen on log file).
I have created a X10 device, light device, M3 for example, and then click on On/Off to control the light. We can see on the log file that command Off or On is sent, but no effect on the light device.
I have checked that mochad service is installed and working properly (active, version 0.1.17), but no effect.
I have also tested the function : nc localhost 1099, and Pl m3 on => it works perfectly.
i have tried to find inside the forum topics related to this issue, but no information.
So, first of all, i'm looking to documents explaining how HS3 is launching the command to CM15, which files are used, how the setting/config are done, to summarize a kind of SW architecture document explaining how it works?
2nd point : if someone has a clue on the issue described above, it will be greatly appreciated to unblock the situation.
thank you for your support
regards
Frederic
regards
Frederic
