"X10" Beta version 3.0.0.47 & 48
    #16
    Thanks for the update Pete!! Ugh, I thought I had resolved the installer help file issue but it looks like I did not. The attached zip file contains the v.48 of the X10 plugin (.exe only) and the Help.htm and supporting image file. Just copy the help and image file to the HomeSeer/html/X10 folder and you'll be good. Note that the help file is old and still needs updating...
    Please let me know if you find any issues and thank you again for your assistance!
    Best regards,
    -Mark-
      #17
      Mark
      Updated afterwards to newest HS4 Beta. That said it loads the plugin fine.
      I can see it under the HS4 plugins and did see an error in the log when starting HS4 newest beta.
      12:44:34:4640:[Startup]->Checking for available plug-ins
      12:44:34:6600:[Error]->Error, Class not found in plugin EXE, maybe namespace is not correct,? Note filename is case sensitive!: HSPI_X10-V146.exe Class: HSPI_X10-V146.HSPI->
      12:44:34:8764:[Plug-In]->Found plug-in: X10, version: 3.0.0.48
      12:44:34:8769:[Startup]->Initializing Plug-Ins
      Connecting to server at 127.0.0.1...
      12:44:35:0751:[Info]->Plugin X10 has connected. IP:127.0.0.1:45834
      Connected, waiting to be initialized...
      12:44:35:0791:[Starting Plug-In]->Initializing plugin X10 ...
      12:44:35:1230:[Info]->Initializing CM11A/12U on COM port /dev/ttyUSB0
      12:44:35:1852:[Starting Plug-In]->Plugin X10 started successfully in 106 milliseconds
      12:44:35:2847:[Starting Plug-In]->X10 loaded in 400 milliseconds
      12:44:35:2851:[Plug-In]->Finished initializing plug-in X10
      - Pete
      Auto mator
      HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
      6.10.0.104
      HS4 Lite -
        #18
        Just renamed the Help.htm to help.htm.
        The add an X10 device doesn't work with the newest HS4 beta.
        Will get back to testing in the next few days.
        - Pete
        Auto mator
        6.10.0.104
        HS4 Lite -
          #19
          I suspect that HS4 is looking for the plugin file name to match the class in the plugin. By renaming the plugin to
          HSPI_X10-V146.exe HS4 cannot find the class HSPI_X10-V146 in the plugin but then figures this out and looks for the HSPI_X10 class. I'll bet if you rename the exe back to HSPI_X10.exe this error will disappear.
          Best regards,
          -Mark-
            #20
            I will just remove it from the Homeseer root directory.
            The adding devices issues relates to adding any device (not just X10) specifically with the new beta version of HS4.
            - Pete
            Auto mator
            6.10.0.104
            HS4 Lite -
              #21
              X10 plugin working fine with newest Linux HS4 beta update version 4.0.3.2
              - Pete
              Auto mator
              6.10.0.104
              HS4 Lite -
                #22
                Thanks Pete! Please let me know if you find any issues as it runs over time.
                Best regards,
                -Mark-
                  #23
                  Will do...
                  - Pete
                  Auto mator
                  6.10.0.104
                  HS4 Lite -
