Just posted version .50 to the Beta section. Most importantly this version adds a 'Clear Timer & Macro Memory' function for the CM11a. Please let me know if you find any issues!!
v3.0.0.49 | Posted: 03May2020 Fixed: Plugin Debug setting was not persistent Fixed: Help.htm referenced file 'hs3_Procedure_create_new_X10_device.jpg'. Changed to 'HS3_Procedure_Create_New_X10_Device.JPG' |
v3.0.0.50 | Posted: 24May2020 Added : 'Clear CM11a Timer & Macro Memory' function to Config page. Added: If the ComPort cannot be opened for CM11a, plugin now checks if the 'x10nets' service is running (Windows only). This service is installed by ActiveHome Pro and will open the ComPort and initialize the CM11a even when AHP is not running. This situation is logged to the HS log and the user must deselect the ComPort in AHP before re-starting the plugin. Updated: Help.htm with new instructions to select X10 interface & ComPort. Fixed: Bug on 'Plugin Config' page - Ti103 settings are not loaded when switching 1st time from CM11a to Ti103. |
