Getting this error message when I enter the Config Plugin page.
    #16
    Mark,
    As requested I tried the edit listed in Post #9. Exact same results. Here are my files:
    Original X10.ini (located in /usr/local/HomeSeer/Config)
    [Default]
    PluginDebug=False
    Protocol=1
    ComPort=/dev/ttyUSB1
    baudrate=9600
    PollInterval=300
    execlog=True
    With item from post #9
    [Default]
    PluginDebug=False
    Protocol=1
    baudrate=9600
    PollInterval=300
    execlog=True
    ignorehcstring=0000000000000000
    Exact same results. I tried just turning off the X10 plugin then turning it back on and rebooting Homeseer. When I turn on the X10 plugin I still get the "**FATAL**: Fatal exception in Ti103.InitX10" And when I try going to the config X10 option I get:
    error - Input string was not in a correct format.-> at System.Number.ThrowOverflowOrFormatException (System.Boolean overflow, System.String overflowResourceKey) [0x0001a] in :0 at System.Number.ParseInt32 (System.ReadOnlySpan`1[T] value, System.Globalization.NumberStyles styles, System.Globalization.NumberFormatInfo info) [0x00016] in :0 at System.Int32.Parse (System.String s, System.IFormatProvider provider) [0x00017] in :0 at System.Convert.ToInt32 (System.String value) [0x0000b] in :0 at HSPI_X10.Web_PluginConfig.GetPagePlugin (System.String pageName, System.String user, System.Int32 userRights, System.String queryString) [0x000c5] in :0
    Thanks for your help.
    Duane
      #17
      Duane,
      I first thought you were off in the number of zero's. But I copied yours and Mark's and put them on top of each other and they are exactly the same.
      The only other thing I can think of, unless there is something else in the .ini file is, is there possibly be any spaces after the last zero?
      If you post your full .ini file, we can compare. It's rather standard for all uses except the ignore values and the debug values.
      Here is mine if you what to side by side compare.
      I see that I have a [Settings} section where it seems that yours does not. I know that going after a .ini file you pass the section name and then the key.
      [settings]
      PluginDebug=False
      Override=False
      [Default]
      Protocol=1
      PollInterval=300
      execlog=0
      ignorehcstring=1111111100000000
      baudrate=9600
      callbacklog=0
      outlog=0
      inlog=0
      rawlog=0
      ComPort=COM3
      George
        #18
        George,
        I compared our files and the problem was the "execlog" value. My file has the word "True" and yours has the number "1". I changed the my file to "execlog=1" and all is good. Here is my current, working file:
        [Default]
        PluginDebug=False
        Protocol=1
        baudrate=9600
        PollInterval=300
        execlog=1
        I did not put the "ignorhcstring" value into my file. Now when I activate the plugin I get a green "OKAY" and I can now do all three functions (Add a new X10 device, Help, or Config Plugin).
        Thanks for all the help!!
        Duane
          #19
          Yeah!!!
            #20
            Gentlemen, upon reviewing the code more closely I see that there are issues with saving and loading some of the other Ti103 settings in addition to the corruption of ignorehcstring. I am working on this and will post a new version soon. Thank you for your assistance and patience!
            Best regards,
            -Mark-
              #21
              Naa we just like bugging you! LOL
              But as someone that still has about 70+ X10 devices, reliability of the plugin is a up on my list. Getting a wrong X-10 code can trigger an event that does something that would not be good. X-10 just isn't used to turn lights on and off, it can be used (as it's generic) as a messaging trigger between desperate systems to ask for or tell something to the other system.
              And before anyone asks about MCQT(sp) and stuff like that, try teaching that to a hardwired OmniPro panel!
              g
                #22
                i install hs4 trial and install plugin for ti103
                my os is windows 10
                i receive this message
                3.0.0.50
                thank you for help
                  #23
                  Hello betheclub99 and welcome to HomeSeer! Sorry for the issue, please install the BETA version of the plugin (v3.0.0.51) which can be downloaded from here: https://forums.homeseer.com/forum/li...eases?t=185551 Be sure to get the Windows version! This BETA build fixes this particular issue with the plugin when run under HS4 and it will be released to the updater in the near future.
                  Once installed, enable the plugin in HS4 and go to the Config Plugin page to setup your com port and other Ti103 settings.
                  Please let me know if this resolves the issue and if not please enable 'Debug Logging' in the plugin. If the config page is still broken with this build you can enable debug logging by editing the X10.ini file located in the Config folder in your root HomeSeer folder. Just disable the plugin in HS, open the ini file with Notepad and change the entry PluginDebug=False to PluginDebug=True, save the file and restart the plugin. Then copy and post the entries in your HS log here, starting with the X10 plugin init entry up to the failure entry so I can see what's happening.
                  Best regards,
                  -Mark-
                    #24
                    I've been running on 3.0.0 51 for a couple of months now and it's pretty stable on HS3.
                      #25
                      Thanks for the update George! I have some new hoops to jump through to get new versions into the updater, hope to have some time for that soon.
                      Best regards,
                      -Mark-
