Mark,
As requested I tried the edit listed in Post #9. Exact same results. Here are my files:
Original X10.ini (located in /usr/local/HomeSeer/Config)
[Default]
PluginDebug=False
Protocol=1
ComPort=/dev/ttyUSB1
baudrate=9600
PollInterval=300
execlog=True
With item from post #9
[Default]
PluginDebug=False
Protocol=1
baudrate=9600
PollInterval=300
execlog=True
ignorehcstring=0000000000000000
Exact same results. I tried just turning off the X10 plugin then turning it back on and rebooting Homeseer. When I turn on the X10 plugin I still get the "**FATAL**: Fatal exception in Ti103.InitX10" And when I try going to the config X10 option I get:
error - Input string was not in a correct format.-> at System.Number.ThrowOverflowOrFormatException (System.Boolean overflow, System.String overflowResourceKey) [0x0001a] in :0 at System.Number.ParseInt32 (System.ReadOnlySpan`1[T] value, System.Globalization.NumberStyles styles, System.Globalization.NumberFormatInfo info) [0x00016] in :0 at System.Int32.Parse (System.String s, System.IFormatProvider provider) [0x00017] in :0 at System.Convert.ToInt32 (System.String value) [0x0000b] in :0 at HSPI_X10.Web_PluginConfig.GetPagePlugin (System.String pageName, System.String user, System.Int32 userRights, System.String queryString) [0x000c5] in :0
Thanks for your help.
Duane
[Default]
PluginDebug=False
Protocol=1
baudrate=9600
PollInterval=300
execlog=True
[Default]
PluginDebug=False
Protocol=1
baudrate=9600
PollInterval=300
execlog=True
Duane
