What is HS trying to do with X10 at the time this error occurs? Are you controlling a device from the UI, controlling a device from an event, receiving X10 data or ??
Best regards,
-Mark-
Does the event run and do the controlled devices switch on?
Is this the only X10 related event that causes the error?
Can you please post a screen shot of the event(s)?
Best regards,
-Mark-
no the event no run, no device switch on or off
i dont not if other event cause problem
I supposed this event cause problem not sure.
Last day this event execute normaly 16:04 and run at 16h39 ?
