When I enable the X10 plugin I see this in the log:
12/31/2020 7:56:50 PMHomeSeer
Warning Plug-in X10 is set to load but was not found, removing from settings. 12/31/2020 7:56:50 PM HomeSeer Plug-In Finished initializing plug-in X10
12/31/2020 7:56:50 PM HomeSeer Starting Plug-In X10 loaded in 1806 milliseconds
12/31/2020 7:56:50 PM HomeSeer Info Plugin X10 with ID: and Instance: has disconnected
12/31/2020 7:56:50 PM HomeSeer Error Initializing plug-in(2): X10 Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in :0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.InitIO(string) at Scheduler.PluginHolder.InitIO (System.String PortNumber) [0x0000b] in :0 at Scheduler.clsHSPI.CheckInterfaces () [0x000bf] in :0
12/31/2020 7:56:50 PM Legacy-Plugin X10 INFO Initializing CM11A/12U on COM port /dev/ttyS0
12/31/2020 7:56:50 PM HomeSeer Starting Plug-In Initializing plugin X10 ...
12/31/2020 7:56:49 PM HomeSeer Info Plugin X10 has connected. IP:127.0.0.1:44524
The plugin status in the Plugin Management screen shows : WARNING: Failed getting InterfaceStatus from X10
Where to from here?
Chas
Where to from here?
Chas
