I have many Lightolier Compose switches in my home. They all work perfectly by themselves. I've been using Homeseer for many years and have been extremely happy with it. I recently upgraded to HS4. all of my devices carried over without a problem and I can operate them manually and through events in homeseer with the following exception. I have created preset dim buttons on some devices, mimicking scene selections. This all worked fine in HS3. In HS4 I can operate the scenes through events and I can operate the scenes if I use the drop down menu or slide control. The problem is with the buttons I have created, when I press the button it send an all off command for the entire house code. So for example, I use house codes A and C mostly for lighting. My livingroom is House code C device code 11. I have 4 preset values set in addition to the on and off buttons. they are 6, 9, 12 and 16 which correspond with my A, B, C and D presets. When I press any of the A, B, C, or D it send the following command: 1/4/2021 8:54:52 PM
Legacy-Plugin
X10 INFO
SendX10: C Cmd: 0 Dim: 0 Data1/2: 0/0
This turns off all house code C devices.
The proper command for the C button or 12 value is: 1/4/2021 5:26:19 PM
Legacy-Plugin
X10 INFO
SendX10: C10 Cmd: 10 Dim: 4 Data1/2: 0/0
I have tried everything I can think of recreating the device with every number of option combinations such as appliance, standard, preset and extended preset. along with every combination of available values in the Status/Graphics menus.
System ProfileDate/time=1/5/2021 7:26:38 PM Eastern Standard Time
Version=HS4 Pro Edition 4.1.10.0 (Windows)
License=Registered
License ID=666073
MyHS Subscription=Basic
MyHS Subscription Backup Interval=No Backup
MyHS Subscription Max Cameras=1
Confguration File=C:\Program Files\HomeSeer HS4\Data\HomeSeerData.json
In Virtual Machine=No MFG: shuttle inc.
Antivirus=
OS=Microsoft Windows Embedded Standard - Work Station
OS Version=6.1.7601
Uptime=2 Days 4 Hours 24 Minutes 50 Seconds
User/Access=richfd (Admin)
Lan IP=192.168.1.85 (hometroller)
Client IP=192.168.1.137 (DESKTOP-HIVT00D)
WAN IP=24.61.52.196 ()
Device Count=76
Event Count=50
Last Event Ran=Device Value Change : 2nd Floor Hall Lights via Motion, Ran at 1/5/2021 6:44:12 PM
Legacy-Plugin
X10 INFO
Legacy-Plugin
X10 INFO
License=Registered
License ID=666073
Antivirus=
OS Version=6.1.7601
Device Count=76
Event Count=50
- of unique event scripts=1
Connected Speaker Clients=HOMETROLLER (127.0.0.1)EFAULT
Processor:=x64 Family 6 Model 58 Stepping 9 at 738.14 MHz
Modules/Threads=117 Modules, 68 Threads
Available Threads=1023
System Load=60 Processes, 8% Load
Free/Total Memory=2.47 GBytes / 3.41 GBytes (72% free)
Free/Total Virtual Memory=5.85 GBytes / 6.81 GBytes (86% free)
HomeSeer Memory Used=80 Mbytes
Plugin Memory Used=5 EXE Plug-Ins using 172 Mbytes
Plugins Installed=GTS CPUXA 3.5.16105.96,SimpleRF 1.3.3.0,Wemo 4.0.3.0,X10 3.0.0.50,Z-Wave 3.0.2.0
