Hello...I am happy x10 is still working on HS4! I have a few 'newer' modules that resume the dim level when commanded ON. Is there a way to send the dim level from homeseer? Is there a way to brighten them? Everything works fine with the 'old' modules...send ON, wait a bit, then dim. On the new ones, sending on restores the dim level. This is ok if no one messes with the switch, but I would like to set an absolute value. Sending ON, then dim 99% dims them slightly more than the restored value. How can I get them brighter?
I am using HS4 with the CM15A plugin and CM15A hw on a Zee.
TJ
TJ
