I am running HS3 on a Raspberry Pi and am using a USB to serial converter to connect the Pi to a CM11a using the X10 3.0.0.50 version of the plugin. For a long time everything was running as well as could be expected from X10 equipment but a few months ago I started getting issues that seem to be getting worse. Every time HS attempts to control a X10 device, I get multiple warnings like this
I thought that perhaps there was an issue with the serial converter so I ordered another one and no changes or improvement. Ok, perhaps the CM11a is going bad so I replaced it with another brand new one I had and again, no changes or improvements. There have been no changes to the Pi and it worked fine for years so I really doubt that it is the issue. I have replaced many of my X10 equipment with Z-Wave but during the holiday season, I have a lot of X10 modules that I use for my holiday displays and decorations and the added number of these devices is making the issue pretty much unmanageable. Some of these items are the Smarthome X10 modules which are leading me to believe that the line noise warning is invalid and the waiting for CM11a to send data is equally invalid. The Smarthome X10 devices all have a power / data light that glows on showing the unit is powered up and flickers when the unit sees X10 data. Whenever HS attempts to control any X10 device, these data lights on the Smarthome X10 devices start blinking like crazy and do it for the entire time the HS logs are kicking out that "Still Waiting" message which indicates that the CM11a is in fact transmitting but your driver is not seeing it and is constantly telling the CM11a to transmit over and over. It does take a long time for the X10 devices to respond so it appears that the transmissions are not clean. In fact, it is also turning on other devices in the same house code that were not intended to be controlled at all.
As another test, I dug up an old X10 clock that can control up to 8 devices on a single house code. It is the one that has 4 sets of buttons and a slider switch that allows you to directly control either channels 1 to 4 or 5 to 8. I set it up to house code C "Christmas" and when I press any of the buttons, the data light on the Smarthome devices flicker briefly and the device being controlled responds instantly so like noise does not appear to be an issue. It seems that all the issue is with HS and the CM11a. I don't recall any of these issues on the much older versions of this plugin, just on this newer one. Is there any way to get a older version or a dumber version of this plugin that just sends the command to the CM11a and ignores anything after that because right now, this is pretty much useless and unusable. Thank you for your time.
X10 WARNING | Still waiting for CM11a to send data... (11.153 sec) |
