I just installed the CM15A plugin and tried to Enable it. My log contains the following:
4/10/2022 2:41:22 PM Legacy-Plugin CM15A ERROR CM15A: Could not start mochad! This version of mochad may not be compatible with this version of Linux. Please install a proper version of mochad and restart the plugin.
4/10/2022 2:41:22 PM Legacy-Plugin CM15A DEBUG mochad launch attempt, LaunchExitCode=0
4/10/2022 2:41:22 PM HomeSeer Plug-In Finished initializing plug-in CM15A
4/10/2022 2:41:22 PM HomeSeer Starting Plug-In CM15A loaded in 1602 milliseconds
4/10/2022 2:41:22 PM HomeSeer Starting Plug-In Plugin CM15A started successfully in 813 milliseconds
4/10/2022 2:41:21 PM HomeSeer Starting Plug-In Initializing plugin CM15A ...
4/10/2022 2:41:21 PM HomeSeer Info Plugin CM15A has connected. IP:127.0.0.1:52352
Here is my system info:
Date/time=4/10/2022 2:48:34 PM CDT
Version=HS4 Standard Edition 4.1.10.0 (Linux)
MONO Version=Mono JIT compiler version 5.0.1.1 (2017-02/5077205 Thu May 25 09:18:45 UTC 2017)
License=Registered
License ID=XXXXXX
MyHS Subscription=Basic
MyHS Subscription Backup Interval=No Backup
MyHS Subscription Max Cameras=1
Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json
Uptime=97 Days 5 Hours 16 Minutes 27 Seconds
User/Access=brad@joyfulhome.org (Admin)
Lan IP=192.168.1.42 (hometrollerSEL)
Client IP=192.168.1.32 (192.168.1.32)
WAN IP=68.42.40.137 ()
Device Count=202
Event Count=32
Last Event Ran=Floor Lighting : P2 Hall Floor Off, Ran at 4/10/2022 2:47:02 PM
# of unique event scripts=0
Plugins Enabled=MeiHarmonyHub:,OMNI:,Z-Wave:,CM15A:
Modules/Threads=73 Modules, 53 Threads
Available Threads=199
HomeSeer Memory Used=138 Mbytes
Plugins Installed=CM15A 3.0.0.8,MeiHarmonyHub 3.1.0.16,OMNI 3.0.2.23,Z-Wave 3.0.4.0
I'm sorry if this already addressed somewhere on the forum, but I could not find it. Any assistance will be greatly appreciated! Thanks!
License=Registered
License ID=XXXXXX
Device Count=202
Event Count=32
