I can't get the interface started. Here's my system info:
Date/time=4/16/2022 3:59:22 PM CDT
Version=HS4 Standard Edition 4.1.10.0 (Linux)
MONO Version=Mono JIT compiler version 5.0.1.1 (2017-02/5077205 Thu May 25 09:18:45 UTC 2017)
License=Registered
MyHS Subscription=Basic
MyHS Subscription Backup Interval=No Backup
MyHS Subscription Max Cameras=1
Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json
Uptime=0 Days 0 Hours 47 Minutes 5 Seconds
User/Access=brad@joyfulhome.org (Admin)
Lan IP=192.168.1.42 (hometrollerSEL)
Client IP=192.168.1.52 (192.168.1.52)
Device Count=202
Event Count=32
Last Event Ran=Floor Lighting : P2 Hall Floor Off, Ran at 4/16/2022 3:53:48 PM
# of unique event scripts=0
Plugins Enabled=MeiHarmonyHub:,OMNI:,Z-Wave:,X10:
Modules/Threads=69 Modules, 49 Threads
Available Threads=199
HomeSeer Memory Used=97 Mbytes
Plugins Installed=MeiHarmonyHub 3.1.0.16,OMNI 3.0.2.23,X10 3.0.0.60,Z-Wave 3.0.4.0
If I select the Plugins - Installed menu, I can see a card for the X10 plugin. It says version 3.0.0.60, with this message:
"WARNING: Failed getting InterfaceStatus from X10 - the interface was not found in the list of active interfaces, the list may need to be refreshed."
Under the Plugins menu, X10 is not show as a menu item.
When I restart HomeSeer, this is the log:
4/16/2022 3:12:36 PM HomeSeer Plug-In Finished initializing plug-in X10
4/16/2022 3:12:36 PM HomeSeer Starting Plug-In X10 loaded in 2409 milliseconds
4/16/2022 3:12:36 PM HomeSeer Info Plugin X10 with ID: and Instance: has disconnected
4/16/2022 3:12:36 PM HomeSeer Error Initializing plug-in(2): X10 Instance::Object reference not set to an instance of an objectSTACK: at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_remoting_wrapper (intptr,intptr)
at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI:InitIO (string)
at Scheduler.PluginHolder.InitIO (System.String PortNumber) [0x0000b] in :0
at Scheduler.clsHSPI.CheckInterfaces () [0x000bf] in :0
4/16/2022 3:12:36 PM Legacy-Plugin X10 INFO Initializing CM11A/12U on COM port /dev/ttyS1
4/16/2022 3:12:35 PM Legacy-Plugin X10 INFO The X10 plugin is attempting to connect to the CM11A interface...
4/16/2022 3:12:34 PM Legacy-Plugin X10 INFO X10 plugin version 3.0.0.60 is starting...
4/16/2022 3:12:34 PM HomeSeer Starting Plug-In Initializing plugin X10 ...
4/16/2022 3:12:34 PM HomeSeer Info Plugin X10 has connected. IP:127.0.0.1:57028
Any assistance will be greatly appreciated!
License=Registered
Device Count=202
Event Count=32
