CM15a: X10 devices keep switching to "OFF"
  • mfisher
    NOTE: thread moved to HomeSeer X10 Plug-in Forum
  • mfisher
    WfromL, when you get a chance please install and test Beta v3.0.0.10 (posted here: https://forums.homeseer.com/showpost...47&postcount=3) and let me know what happens.
    Digging into the CM15a plugin code I see that the plugin assumes all RF traffic received would only be X10 traffic! This results in all non-X10 RF traffic being passed to the callbackX10Event() code within the plugin with invalid Device, Command and Value parameters. Your device which results in the log entry "CM15A DEBUG Received CM15 Address:M1, Command:socialite,7e,7b,f2,71,84" is being improperly passed to the X10 processing logic as "M1 AllUnitsOff".
    The beta version I just posted tries to address this by blocking all received data (PLC or RF) that is NOT one of the following commands: AllUnitsOff, AllLightsOn, On, Off, Dim, Bright. It will also log the data that was received to the HS log so we can better see what is happening.
    Since there is no way for me to test all of the possible RF devices out there, please post the log entries for devices that need to be added and I will try to add them to the code.
    Finally, I am going to request this thread be moved to the HomeSeer X10 Plug-in forum so that others can find this info when they have similar issues.
  • Steve Q
    Originally posted by WfromL View Post
    I have been running HS3 with my weird simultaneous X10+"................RF commands are received by CM15A and executed 100 %, ...................... .
    Can you provide more information about how you receive RF commands with the CM15A. I was not aware this was supported by the HS3 plugin for the CM15A.
    Steve Q
  • WfromL
    Update April 12 2015
    I' thought I'd mention this in case anyone is interested:
    Still running the same HS3 +X10+X15 setup on Windows 7 as a temporary solution. Has been faultless for 4 months now.
  • WfromL
    Update on HS3 with CM15A+CM12A
    I have been running HS3 with my weird simultaneous X10+X15 configuration for more than a month now: RF commands are received by CM15A and executed 100 %, power line x10 commands are received, sent and executed 100 % by CM12A.
    This is the most reliable Homeseer I ever had, has been running for over a month without shutdown.
    I still wish the Homeseer team could solve the CM15A "status off" problem, then I could ditch my old CM12A interface.
  • jyves@videotron.ca
    I have an extensive X-10 installation for more than 15 years.
    My existing system is based on an OmniPro-II and an X10-Pro PCS-05 interface,
    With all the required filter, bridge and whatnot.
    I also have one Power line signal analyser (lucky me).
    I presently do some testing with my new HS S6-Pro troller.
    I set-up and test adequately Insteon PI/Devices, ZigBee PI/Devices, and ZWave PI/Devices.
    I received my CM-15 two days ago.
    God, what is that!
    Devices C5 is working when controlled with HS WebControl device on/off button, but I also see on my analyser other signal like C5 On and C9 on, there is no such event in my systems.
    I manage also to make an X10 device work with a HS event!
    Initially, trying to put an On button with HSTouch get no success, no signal at all transmitted on power line. Playing with C5 status graphics in configuration (Disabling the 2 On/Off line, or renaming the second On/Off string), get bizarre result. When pressing On button, I was able to send some signal, partial and non-related to what I was programming (like signal CDM, meaning device C dimming, but the address in not complete, C5, and the Dimming option on that device is not enable).
    What HomeSeer engineer are saying on that issue???
    JYA
  • WfromL
    Hi Rupp,
    thanks for pointing out, but I am aware of that problem and I would certainly not recommend anyone to do likewise. It is however an attempt to finally move to HS3. I feel HS3 is definitely better than HS2, but HS2/X15 has served me well for many years and I have so heavily invested in X15 that I hate loosing it.
    Some of my X15 devices are neatly hidden behind a wall, replacing them would involve a lot of handiwork and a repainting job.
    I guess you are probably convinced that I'm experiencing noise, I have done so many tests that I know it is not noise (I am a -albeit retired- professor of experimental plasma physics, I know about noise).
    I have one option left: moving to HS3 on Linux. HS3/X15 works perfectly on Linux (come to think of it, one more reason why my X15 problem cannot be noise). I missed however the UltraNetCam plugin, but I just today discovered that UltraNetCam is now available for Linux, so I will give it a try.
  • Rupp
    Having two X10 interfaces plugged in and working at the same time can cause all kinds of issues such as random noise, looping command calls, etc. Without an X10 signal monitor it's impossible to know exactly what is being transmitted on the powerlines.
  • WfromL
    Thanks for letting me know I'm not alone any more!
    I have been testing HS3 from its first beta release, now more than a year ago but I only recently migrated everything to HS3 (now on beta .149) because of the X15 bug. As I have a lot (15) of X10 devices I had to reinstall Windows 7 because Win 8.1 has no drivers for the X10 (CMA11A). I have now the X10 and the X15 interface simultaneously installed for all my devices. I need the X15 copy to ensure my RF remotes work OK. The status of my X15 devices changes to OFF randomly, but I disregard their status of the X15 copy and only take into account the X10 copy. It's not elegant, and at times it's complicated, but it has been working reliably for over three weeks now.
    You may want to add your bug to my bugzilla:
    http://bugzilla.homeseer.com/bugzill...ug.cgi?id=2266
    My X10 devices have been working reliably for many years with HS2. For new devices I recently purchased Z-wave but I cannot say they are more reliable and therefor I don't feel the need to replace all X10/X15 with Zwave. The only advantage I can see is that Zwave reacts immediately, while X10/X15 sometimes has a delay of several seconds.
  • LxMeister
    it's not just you!
    Okay, I've finally been able to get logged in here to start with this. I too am having all the x10 icons on Homeseer 3, (CM15A, Windows XP) just turn off. The actual lights stay on, but HS3 indicates then all off.
    However! In my case, I have isolated it down to an "extended dim" command. One of my newer X10 wall switches supports it, so I tried to include levels in some events, and there it went.
    I'm thinking there are a few bugs yet in the HS3 CM15A plugin. For me, Extended Dim does it, for you, the MTCDDVD, whatever that is.
    I've also noticed that HS3 doesn't actually trigger off incoming X10 commands, only off virtual devices set to those addresses... Which is unfortunate...
    And, it doesn't really support "All off" commands, instead it sends an off for each unit code, at 1 second apiece so it takes 16 seconds to turn off a whole house code instead of 1. And since it can't trigger directly off received X10 commands, like "F All Off", I can't have it send an all off to my Z-wave devices.
    Sorry, that started to ramble and I don't know if those need to be separate threads, but they all seem to be related to the CM15A plugin on Windows, and not knowing what to do with some of the more "new" (?) parts of X10?
    Of course, I have no idea where else to go with this, I'm pretty new.
    -LxMeister
    -HS3/CM15A/Z-Troller, slowly migrating X10 to Z-Wave.
  • WfromL
    Nobody else has this problem?
    CM15A on HS3/Windows is still unusable for me.
    Anybody else using a DS90 or a Somfy remote? The RF signal of both these devices trigger the CM15A devices status (reliably!!!, not noise!!!) to "OFF" (but they don't actually switch the devices).
    Same CM15A on HS3/Linux or HS2/Windows works perfectly, so the CM15a is not defective.
  • WfromL
    No problem with HS3 on Linux!
    Update!
    I updated to HS3 .143 on UBUNTU. This version finally works with CM15A, and all X15 events work perfectly. No problem with the infamous M MTCDDVD code.
    Have been running for over 24 hours now without any problem.
    The HS3 linux has as latest X15 plug in 3.0.0.4, so I tried to copy the old 3.0.0.4 versions of Windows to a HS3/Win .143 installation, but no luck: the bug is definitely there in HS3 Windows!
  • WfromL
    Just to make sure I hadn't a defective DS90 I borrowed two more Marmitek DS90's from friends.
    Exactly the same problem: The keep alive is interpreted by CM15a plug in as
    MTCDDVD. I noticed that opening the case, thereby triggering the tamper switch, also generates this code, but normal operation (door open or closed) does not.
    Again, the RFXCOM receiver interprets these RF signals correctly.
  • WfromL
    Tracked down the culprit!
    I finally found the culprit, and it's not noise.
    I searched in vain for a source of noise, unplugged the whole house until I ended up with just my computer and the CM15A interface: the problem remained just the same. With nothing else connected to the power line I realized the rogue signal must be X10-RF. I then noticed the switching of all X15 device status to off occurred with 2 periodicities: 84 and 78 minutes, seemed like a "keep alive" signal. I then looked at X15 with my old ActivHome software, and sure enough: there was a "Receive RF M MTCDDVD" message coinciding with my problem, 100% reproducible. To find which device did it I used the RFXCOM RFReceiver: that gave me finally the culprit: a Marmitek DS90 door sensor (the only RF X10 device I have). Taking the batteries out and the problem (almost: see the bad news at the end of this message) disappeared. A Google search for MCTDDVD wasn't very conclusive: as I understand it, it is either a bug or a legitimate (but undocumented?) X15 RF code, but nobody seems to know what that code means.
    Now the bad news: I can also produce the M MTCDDVD code with my SOMFY RTS remote but in this case it is only 80% reproducible. Really strange behaviour: Somfy is not an X10 RF signal so why is it registered as such by HS3, and why only 8 out of 10 occurrences? I can replace the DS10 door sensor with a Visonic, which gives no problems, but I cannot change my Somfy blinds motors. So my problem isn't solved.
    Anyway, I consider this to be a bug in the HS3/CM15A plugin. The HS2/CM15A combination doesn't register this weird MCTDDVD code, so it should be possible to ignore it with HS3 too.
    It would help if there was a possibility for CM15A to "ignore" a specific houscode, such as is the case with the ACT TI103 X10 interface.
  • WfromL
    Tnx for all feedback!
    Steve: good to hear your CM15 works reliably, so it must be something wrong with my setup, I'll continue experimenting
    Pete: I'm monitoring ports now, so far nothing significant showing
