I am experimenting with the Zee updated to the latest 3.0.0.181 with the 3.0.0.36 X10 Plugin. I am testing with a CM11.
When I define a new device I get no X10 tab to complete.
If I change the X10 plugin config to say there is an imaginary TI103 present and define a new device I get the X10 tab appearing. When I then change the plugin back to reflect real CM11 I can control the X10 device defined whilst the "TI103" was present.
I can cope with it but it is a bit of a nuisance and I assume a bug unless someone can correct me?
I tried to create another X10 interface instance thinking I could just say that was a TI103 but it appears that all X10 interfaces on differet instances need to be the same so that doesn't help. In the process I also had the X10 config page come back with "Need to override this function to generate a page!" which looks like a developer forgot to do something?
Hopefully this will avoid someone else puzzling over why no X10 tab.
