I upgraded from a very solid HS2 installation, same PC but totally updated with new motherboard, memory etc.
in HS2 using x10 was a beeze, in HS3 I must say this is not so straight forward as it seems X10 is not ma well supported protocol.
I currently have the X10 interface by homeseer with a CM11a interface, I have two and have tested both. I get the occational message in the log:
CM11A Possible no response to send data, still waiting
this happens at ramdom, the more commands are sent the more this seems to happen.
then it gets worse, I have multiple x10 motion sensors in my home, I use the BLRF plugin to get their signals, this seems to work fine. I recently tried using a plug in controller to do some stuff and I had an extra x10 receiver in my garage where RF signal does not reach the main receiver.
anyway, I noticed when a few commands are received via powerline the plugin seems to freak out and set every device on the house code to the same setting, ie, if I get a few on commands in a row, all of the sudden every item on that house code goes to ON in homeseer, the weird thing is that this is not noted in the log but events I have set to these devices do trigger, driving me nuts.
I tried disabling the BLRF plugin, no difference, I then figured I would try a CM15a but that uses a whole different setup and its not compatible with BLRF anyway.
so does anyone have suggestions, I tend to think the issue is the cm11a plugin and in more detail I fear there is some issue getting serial data properly hence the first error and then the new one. any suggestions would be appreciated.
