Originally posted by outbackrob
View Post
I assume you are using the same CM11 plugged into the same outlet in all cases (including HS2 vs. HS3). I have had numerous cases where a specific circuit - or even a specific outlet - was problematic. Have you tried using an extension cord to test the CM11 on different outlets?
Also, the CM11 output is not very strong. I moved to an XTB 232 several years ago and saw a significant improvement in performance.
Do you have access to an X10 meter? It might be helpful in tracking down the source of the problem.
The stumper is the difference between HS2 and HS3. I haven't noticed any difference between the two related to the power line signal itself. It was getting HS3 to send the signal I wanted (especially preset dim) that was the major problem for me. That, and figuring out how to create an X10 device properly.
