I "think" I have my X10 stuff working as it should (almost) from my Zee S2. On the CM15A tab I switched from "Standard dim" to "Extended" and now my dimmer switches seem to work just fine (almost). If a switch is off and I slide to 50% I would expect the switch to go on and go to 50%. However, I can only get the light to come on by switching "On" and that takes the light to 100%. Am I missing something in the screen setups?
My other issue is that if I adjust the light at the switch, it doesn't reflect the change in HS3 or HS Touch. Suggestions appreciated. The CM15A version is 3.0.0.5
