ok so I watched this video and not following. I know how to wire switches, etc..
https://www.youtube.com/watch?v=Fx1luE9llSQ
what I have is a box on one end of the hallway. the power line is there. the other switch at the other end of the hallway is the one that goes up to the light.
so what I thought was easy...
ground - green
common - white
load - light
power - ????????????????
now on the video he says connect 2 wires together. so you hook up common but I'm not following where the power is. is the power going into the traveler?
so what I'm thinking it is will be like so...
slave switch
common - white
black (power) AND say Red traveler both into the traveler screw? so that will get the power over to the other switch?
ground - green
common - white
load - light
slave switch
common - white
