Issues with Jasco Z-Wave PLus In-Wall Smart Motion Dimmer (26933)-Solved!
  • #61
    Once this issue is squared away I will update the S2 one also.
    Originally posted by logman View Post
    What about the S2 version of Z-Wave? I noticed there have been about 10 updates to the regular Z-Wave interface since the S2 version was introduced.
    --Barry
    • #62
      rjh I am getting Type 0x494D and Product ID 0x3034.
      • #63
        I installed the beta z-wave plug-in and didn't see any change in behavior for my switch (I have the switch - not the dimmer), until I removed the switch from the network and re-added it. Now it is reporting motion. Thanks.
        • #64
          I have several questions myself on this switch including the timeout parameter. I really want to disable the timeout when the button is pushed manually on, then enable it when pushed manually off.
          I also want o know where the hell the LED is because I can’t find it and am afraid of breaking it to remove the covers looking for it.
          • #65
            I just installed one of these. I am having some issues. I am on z-wave 3.0.1.252. I am not getting status updates, the motion sensor does not work at all, and the indicator LED on the switch is off permanently ( and unlike other Jasco switches I do not see any LED settings on the z-wave tab). Having read through the whole thread it seems that a lot has been improved with the z-wave plugin to support these switch\motions sensors since the thread was started in 2017. Can someone point me in the right direction to get this working with the new z-wave plugin. I have attached photos of devices, node info, and settings I see. Any help is much appreciated.
            _______________________________________________
            HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
            Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
            Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
            • #66
              My problem with this is I don't see a No Motion event. Im trying to create a event that would turn this off after 10 mins of no motion but I dont see that available. How can I get around this?
              • #67
                No Event in your image is the same as No Motion. When the sensor goes from sensing motion to not sensing motion, the HS device will update to status No Event.
                -Wade
                • #68
                  Do you have the light sensor on or off? It may not be reporting motion if the light sensor is seeing light.
