I've got a few Aeotec Micro Dimmers (the older G2 versions, not the new Nano ones) that are installed and working fine on HS3.
The only issue I have is that by default they are set to switch back on to the 'Last Level' if they are switched on by the physical wall switch (i.e. if they were at 30% dim when I switched them off, when I press the wall switch again they'll turn back on to 30%)
I'd prefer if they always turned back on to 100%/ON after being off.
I've created a simple HS Event using EasyTrigger that achieves this. If the light changes to any level over 1% after being off, the event changes the dimmer to ON/100%.
The only problem with this is that sometimes there is network/system lag so the ramping up effect becomes very noticeably delayed.
Is there any way to program the default behavior of the dimmer to always switch back to ON, rather than to 'Last Level', so that I don't have to rely on an event/script to achieve this?
I've read through the documentation but none of the parameters seem to be what I'm looking for.
Anyone with some advice?
