Having issues with the Qubino Flush 1D Relay (UK version)
Have had one installed for a couple of months and has been working fine. It then started to stop responding intermittently in that the relay would not operate despite HS showing correct status change. Relay would change OK if switch on I1 was operated, and status would also correctly change. Not done any changes to HS or the plugins so not sure why things changed.
Assumed unit was faulty so Removed the node on HS by clicking on I1 5 times. Strangely another Qubino unit (a Flush 1 relay) on the other side of the house got excluded instead. A second attempt on the unit successfully excluded it.
Tried three replacement Flush 1D units. All failed to operate in the same way when controlled by HS but status changes as if it had operated.
Other Qubino units seem ok its just the Flush 1D I'm having issues with.
Any ideas or suggestions greatly appreciated.
Current Date/Time: 30/12/2017 11:34:21
HomeSeer Version: HS3 Pro Edition 3.0.0.368
System Uptime: 0 Days 13 Hours 1 Minute 25 Seconds
IP Address: 192.168.1.15
Number of Devices: 520
Number of Events: 309
Available Threads: 400
Enabled Plug-Ins
3.0.1.90: PHLocation
3.3.5.17921: SMS-Gateway
1.0.2.0: SurveillanceStation
3.0.6551.16959: UltraGCIR3
3.0.1.130: Z-Wave
Enabled Plug-Ins
3.0.1.130: Z-Wave
