Fibaro double relay showing "UNKNOWN" - Solved!
  • Fibaro double relay showing "UNKNOWN" - Solved!
    I just included a Fibaro double relay and got a whole load of devices for the switches, power management etc, all good.
    It actually seems to work i.e. stuff turns on and off through the controller, and if I physically switch them the device values change between 0 and 255.
    BUT the display always shows a status of "Unknown" !
    I checked the settings for status graphics, control use etc and the correct entries appear for 0 and 255.
    My log shows a probable issue:
    (off manually)
    Aug-10 20:58:08 Z-Wave Device: Outside Pond Pond Pump Set to OFF
    Aug-10 20:58:09 Z-Wave Device: Outside Pond Pond Pump Set to INVALID VALUE
    Aug-10 20:58:09 Z-Wave Device: Node 2 Z-Wave Watts 1 Set to 0 (0 Watts)
    (on from controller)
    Aug-10 20:59:17 Device Control Device: Outside Pond Pond Pump to On (255) by/from: CAPI Control Handler
    Aug-10 20:59:18 Z-Wave Device: Outside Pond Pond Pump Set to INVALID VALUE
    Aug-10 20:59:20 Z-Wave Device: Node 2 Z-Wave Watts 1 Set to 25.3 (25.3 Watts)
    Has anyone seen this, and have any idea how to fix it?
    TIA
    What version of the z-wave plugin are you using. I experienced similar with Aeotec and the latest beta plugged in but when I rolled back to .190 they enrolled correctly.
      Sorry should have thought to provide that - I'm running the mainline version, not beta.
      RaZberry 2 running on a Pi 3 B+ with Raspbian Stretch
      HS3 3.0.0.435
      Z-Wave 3.0.1.190
      I'm not sure what you mean by "enrolled correcty" - you mean the valid values are part of the pairing process, so re-pairing may help I guess?
        This is fixed in the current beta :-)
        I was trying to stick with mainline versions during my trial, but from reading other threads the Z-Wave beta seems pretty stable.
